00 Scrub
Hi, I am in the process of hardwiring my A119 v3 to my 2005 TSX. I am using the Viofo 3 wire hardwire kit. I however am not getting power to the dashcam. I have spliced a fuse tap to the Bat+ line from the hardwire kit box put the fuse tap into fuse number 32 labeled "ACC" on the fuse box diagram. This provides 12V when the ignition key is put into ACC. The other end of power cable is plugged into a GPS base. I have not spliced the yellow wire labeled "ACC" from the hardwire kit box to anything as there is no room for the fuse tap in the fusebox. I have the OEM 7.5A fuse on the slot closest to the blades and a 2A fuse in the other slot.
See:
Does anyone have any ideas? Can I use the hardwire kit with only the Bat+ line? Do I need to change any settings on the dashcam>
The dashcam works when plugged into a cigarette lighter adapter.
Thanks!
See:
Fuse Box Diagram Acura TSX (CL9; 2004-2008)
Fuse box diagram (location and assignment of electrical fuses) for Acura TSX (CL9; 2004, 2005, 2006, 2007, 2008).
fuse-box.info
Thanks!
