Hi quick question i have to B40 dascams(front and back) that i want to hardwire but not sure if i should hardwire each one by itself or could i just harwire them both positives to 1 piggyback holder?
Just have them on the same fuse tap if that's easiest for you. They aren't going to draw that much anyways. I'm planning on moving my A118C to the back of my vehicle when I get my A119S and I'll be running both off the same fuse tap/power, which is powering a dual usb power adapter like this one.
thanks you are right 1 piggyback should be fine as they dont draw too much ,i got this 2 of these 1 for front and 1 for back https://www.ebay.co.uk/itm/381406329221,will solder both and then use some crymplex to shrink and cover them ,which fuse are you using/should i choose?
what is a A119S ???
