Welcome to the club @rohWhat could be the reason ?
That is correct, updating the firmware shall solve the issue usually.Welcome to the club @roh
1.) Are you saying you want;
a.) 2K60fps (HDR Off) DAY
b.) 2K30fps (HDR On) NIGHT
2.) Can you post a screenshot of your A229 Plus camera firmware?
I remember this was an issue during A229 Plus release (2023), and it was fixed with a firmware update.
-Chuck
Hi Chuck. Thanks for the revert. Yes, what you said is what I want. Attached a snap of the current firmware. RegardsThat is correct, updating the firmware shall solve the issue usually.
Thank you for the confirmation, and the photo of current firmware.Hi Chuck. Thanks for the revert. Yes, what you said is what I want. Attached a snap of the current firmware. Regards
Incorrect.If your firmware is an older version. You should update to newer version.
Thank you. I will factory reset and revert on the outcome. Best wishesThank you for the confirmation, and the photo of current firmware.
It looks like your firmware is up to date.
1.) I would perform a Factory Reset / Default Settings.
2.) Re-enter your setting and re-test for proper operation.
3.) If you still have malfunction I would SUBMIT A TICKET directly to VIOFO for assistance.
A229 Plus: Firmware as of October 13, 2026
Front: V1.5_260813
Rear: V1.3.1_250421
If your firmware is an older version. You should update to newer version...
A229 Plus Firmware
edit: typo
Incorrect.
False & Misleading Statements.
IMPORTANT NOTE:
If your rear camera is currently functioning normally, we strongly recommend NOT updating the rear firmware.
This specific update is intended only for resolving certain hardware issues.
Updating a perfectly working unit may cause unexpected errors.
Manufacturers saying that you shouldn't update a firmware is just poor quality assurance on their part.Now, now, Chuck. No need to be angry and accusatory. ๐ It was a typo driven by lack of coffee.
