The WiFi on our camera is just access to connect the camera to your phone, it is not really LTE.
...........................have no idea what LTE is
To enter the live view after connecting to the WiFi, you need to disable the VIOFO app from accessing the cellular data on your phone. Here are details explaining this:
https://support.viofo.com/support/solutions/articles/19000127932-why-can-not-i-use-the-viofo-app-
.......................oy. I am supposed to or can understand these instructions? I am a retired salesman in Florida, not a candidate for the Geek Squad's next hiring round. Sorry, but this A139 Pro has brought a fair amount of stress into my life...you know...$350.00-ish for the 139 and the wire harness, another 200.00 to install it beautifully and now I am possibly looking at ripping it out of the car and sending it back to Amazon.
If you have remembered the WiFi of our camera,
.....................remembered on my phone?
.....................remembered on the viofo app?
your phone may connect to it in priority.
So it is better to turn off the wifi when you don't need it.
........................so -----when I get in the car I need to turn the wifi off EACH time I use the car and then turn it back on when I exit the car? Yes? Really?
Besides, it will also bring more heat with the wifi turning on all the way.
............................with all due respect ---not my problem.
Let me ask you something. The model down from the A139, the A229? Does the A229 ELIMINATE all the wifi/remembering wifi/LTE etc and just put what the camera sees onto a chip? If so, that eliminates all these exoticly complicated fixes recommended here.........yes?
Here is what I am looking for:
..............I get in the car
..............the dashcam turns on by itself
..............I am not required to turn anything on or off - phone or dashcam
..............I am not required to adjust any of the settings on my phone that allow it to perform its job as a phone...to accommodate the A139
.............I live my life normally in the car listening to whatever I want on the internet via my phone bluetoothing to the car radio
.............the dashcam requires nothing of me to do or turn on or anytjing when I am using my car
.............the dashcam will provide video data when I need it via its chip and I guess a chip reader?
.............I finish driving and exit the car - nothing required to turn off or on on my phone or on the dashcam
I am getting the feeling the A139 Pro can't perform like what I am outlining above........yes?
Does the A229 perform as I outlined above?
Given the myriad of solutions offered here, it appears the A139 Pro is incapable of doing its job quietly in the background and does require some measure of fiddling with the phone or the dashcam or both each time I use the car...............................unacceptable. Too, it also appears that I have to modify or possibly reduce my phone's capability to prevent the A139 Pro from BLOCKING my phone's access to the internet.
Thanks for your help on all this. I had no idea the complexity arena I was stepping into.
