High resolution and low light performance - best 2ch-4ch?
rjk
uʍop ǝpısdn
I'm coming from an old Qvia AR790M-2CH system that is starting to get flaky. Video from the rear camera flashes and has lines. The problem is that this causes a constant motion detection so actual motion events get overwritten. This existing system is FHD+HD front/rear if I remember correctly.
My understanding is that higher resolution usually results in worse low-light performance. What is the best compromise of high resolution and low light performance these days? I want at least 2 channels again, and may be open to adding side cameras if someone makes a good 4 channel system. I want a minimum of 1080p. The highest possible bitrate, the better.
I actually installed a lithium battery in my car and it lasts so much longer than the lead acid battery. I can leave it recording for a week and still have no issues starting up later. So I want a good parking motion detection system as well as constant driving recording, with GPS to keep the time accurate.
Given your requirements for high resolution, excellent low-light performance, and robust parking features, I recommend considering options from VIOFO or Thinkware. Both brands are known for their quality and reliability.
For a dual-channel setup, models like the VIOFO A229 Pro would be a great fit, offering 4K UHD front recording and 2K QHD rear recording, which balances high resolution with low-light performance thanks to its Sony STARVIS technology. It also has excellent parking mode features, including buffered recording and motion detection, perfect for your needs.
If you're considering a 4-channel system, the VIOFO A229 Pro can be expanded with additional cameras for side coverage, giving you comprehensive protection.
Additionally, these models come with built-in GPS for accurate timekeeping, and the high bitrate will ensure you get clear footage without compromising quality.
If you need more specific models or assistance, feel free to reach out to our support team at info@blackboxmycar.com or via Live Chat on our website.
  • Like
Reactions: rjk
I looked at the VIOFO systems, and don't see any that have more than 3 channels? How do you add a 4th channel?
The VIOFO systems typically support up to 3 channels. However, to add a 4th channel, you would need to look into a modular solution like the Thinkware Multiplexer, which allows you to connect additional cameras to a compatible Thinkware dash cam.
If you're specifically interested in VIOFO and need a multi-channel setup, you may want to consider using multiple VIOFO dash cams for different angles or configurations. For more specific configurations or recommendations, feel free to contact our support team at info@blackboxmycar.com
