Thank you. Is the KML a simple static line on the map showing the entire route from start to finish, or is it a pointer animated on the map in 'real time'? If it's the former, it's no use at all. If it's the latter then that's perfect. All I need then is a way to get that animation into Adobe Premier (for Windows).
[Edit: I want to find a .mp4 created by the Panorama II with GPS data so I can test the export of a KML from RV and then the import of that into Google Earth and the export of a KMZ to be imported into Adobe Premier.
Can anyone point me to an MP4 I can use, or maybe share a 1 minute example please?
Many thanks.
