Well,I will try it your way,but I don't think it will last too much longer than this in video above.Not even a minute in my estimation. To check, instead of unplugging it until it shut down, I turned it on while unplugged and fully charged. It showed the battery to be full but then quickly dropped a bar and then shut down shortly thereafter showing no bars. Not sufficient time I think to show a police officer what happened without an alternative power supply handy.
FWIW & IMHO, unplugging it from a power source then waiting for it to shut down wont show the actual battery life because the camera is designed to automatically initiate a shut down procedure once external power is removed.
I tried but didn't have time it till turned off by itself,worked for 3 minutes and I stopped measuring time.When I have more time I will test it properly.(First I turned the dashcam off,and charged it until red light stopped,then I pull out cable from power source and turned dashcam on by pressing the ON button and it lasts 3 minutes.)š I dont that it will either, as noted in my comment, on its own power, mine doesnt last long at all
As you can see on video,I use button on the right side to turn dashcam on or off while its still connected to power.How do you turn it off, while its still connected to power?
I think what you are searching for is on 2:34 at video.Video is long because I had to test it and record it,that other people can see and follow video step by step and test your dashcam youself and how long does battery lasts long without power source on its own battery.I hope I understood what are you asking me and helped you.It's not clear since the video is so long, exactly what is being shown, but I do get your point that the battery probably isn't being charged, unless you turn off the video and leave the power connected, to charge it. What isn't clear is exactly how to turn off the recording, to accomplish that. Can you point to an exact point in the video where you demonstrate this? Like at 14:17
Now,try how long they(both dashcams) will lasts long on their own batteries and share your results with rest of us.While you waiting dashcams to go off and battery drains,you should enter a menu and push buttons on your dashcam to drain the battery faster,because that is really what you gonna do if you need to show your recorded video to a police officer or insurance agent ot anyone else.Thank you, yes that was what I was looking for. I just held down the power button and its remaining red, so I'm guessing its charging now. It must not every build up a charge in the battery from the normal on/off again usage where its always recording. I'll leave it plugged in (I have two of them) and see how long till the red light goes away (indicating full charge). Thanks !!
