As kamkar1 said, the capacitor will not run the camera while you drop off deliveries if the engine is off. It only runs for a few seconds to save the last video file.I do not plan on wiring this into my car use the g sensor.. it has a supercapacitor.. if I get get out of the car and turn it off for a few minutes and get back in the camera still be running? I deliver auto parts. Sometimes I go right back on the road other times I might have to wait 5 minutes for another order.
As Nigel said, if you want to keep all the 8 hours, a 64GB card is just about enough. 30% (about 10g)is reserved for events so you only have 70%(35Gb) for normal recording.Thanks. I didn't know cards were so cheap now. Looks like they only support up to 64GB.
A powerbank sounds like a good option to keep the B1W running all day. 10000mah is enough for 8 hours.
If your car has permanent live 12v socket then that would be your first choice.
if you hard wire the B1W it need to have a discharge prevention in the hard wire kit, but other than then when you leave the car the camera go into parking mode after a minute or so, and a kick to the rear wheel ( wearing snickers ) will be enough to trigger a event recording.
Actually i was amazed it trigger so little while i drive Vs how easy it trigger when in parking mode, but there are just one sensitivity setting i assume only go for driving, and i dont think its the same when it is parked where i think it is more sensitive.
If your ride have a always on cigarette plug, or one with a delayed off, then your deliveries will be fine i think.
But other than that you do need to hard wire the camera to get coverage when parked, otherwise the camera just do the default all dashcams do which is turn of or on with the car.
You can easy use a USB power bank to power the camera all day, then you just need to charge it in the evenings as most power banks dont support both charging and use at the same time.
Using a power bank was how i tested the parking mode of the B1W as i dont have a hard wire kit in my car yet.
Or you can do hardwire connection with your car always-on socket, so it can keep recording even if your car parking!Just a question also if anyone knows the answer..
Yeah good idea. Not sure why I never thought of a power bank.
