How to export the GPS track from the video of LS580W
jetsun
China
It seems there is no LS580W outside of China.
Sony Exmor CMOS, 5x GPS
I guess it may corresponding to LS430W or LS460W.
I want to export the GPS track from the video of LS580W and tried following tools,
1) Registrator Viewer by Vadim Andreevich Kozlov (http://www.registratorviewer.com/index_en.html)
Registratorviewer seems not compatible with LS580W, the exported GPX file has no track.
2) http://bigbugisoftware.jigsy.com/gpx-extractor
Extracting GPS GPX info from Dashcam video using OCR
Failed
3)http://dashcamviewer.com/
The output GPX file has no lat and lon, speed.
J
jetsun
China
I write a Python program to export the GPS data from DOD LS580W video file.
Code:
#!/usr/bin/python
#Extract GPS data from video file of DOD car dashcam to GPX file.
import os
import mmap
import struct
import binascii
n_chunk = 400 # each GPS data item is 32 bytes
filename="2017_0127_131010_022.MOV"
#The GPS data segment start with freeGPS('\x66\x72\x65\x65\x47\x50\x53')
data_prefix=b'freeGPS'
item_prefix=b'$S'   #'\x24\x53'
version =    '<?xml version="1.0" encoding="UTF-8"?>\n'
version+=    '<gpx version="1.0" creator="DOD video to GPX - by jetsun@gmail.com" '
version+=   'xmlns="http://www.topografix.com/GPX/1/0">\n'
track_start='  <trk>\n    <name>{}</name>\n    <trkseg>\n'
track_point ='      <trkpt lat="{}" lon="{}">\n'
track_point+='        <time>{}-{:02}-{:02}T{}Z</time>\n'
track_point+='        <speed>{}</speed>\n'
track_point+='      </trkpt>\n'
track_desc ='    <desc>Max Speed:{:.2f}km/h at time:{}</desc>\n'
track_end=  '    </trkseg>\n  </trk>\n</gpx>\n'
with open(filename, "r+b") as f:
    try:
        mm = mmap.mmap(f.fileno(), 0)
    except OSError as e:
        print("OSError({0}): {1}".format(e.errno, e.strerror))
        print("The 32bit Python cannot handle huge .mov file")
        print("Please install the 64bit Python")
    else:
        start=0;
        count=0;
        maxSpeed=-1
        maxTime=""
        file_name, file_extension = os.path.splitext(filename)
        gpx_filename=file_name+'.gpx'
        gpx_file = open(gpx_filename, 'w')
        gpx_file.write(version+track_start.format(filename))
        while True:
          freegps=mm.find(data_prefix,start)
          if freegps==-1: break
          mm.seek(freegps)
          start=freegps+6
          #print(freegps)
          buf=mm.read(n_chunk)
          dataItem=0
          while True:
             dataItem=buf.find(item_prefix,dataItem)
             if dataItem==-1: break
             #24 53 00 00 10 8B year month day hour minute second latitude longtidue 10 00 00 00
             gpsData=buf[dataItem+2:dataItem+25]
             unknownData=buf[dataItem+4:dataItem+6]
             #print(binascii.hexlify(bytearray(gpsData)))
             dataItem=dataItem+2
             speed,unknown1,year,month,day,hour,minute,second,unknown2,latitude,longitude,last=struct.unpack('!HhH4BHB2iH',gpsData)
             if last!=4096: break
             latitude=latitude/10000000.0
             longitude=longitude/10000000.0
             speed_mps=speed/100.0     #Meters per second
             speed_kph=speed/100.0*3.6 #Kilometers per hour
             strTime ='{:02}:{:02}:{:04.1f}'.format(hour,minute,second/10.0)
             strSpeed='{:6.2f}km/h'.format(speed_kph)
             #print(strTime+' '+strSpeed+' '+'{:<11}'.format(latitude)+' {:<11}'.format(longitude)+"   "+" ".join("{:02x}".format(c) for c in unknownData))
             track_point_data =track_point.format(latitude,longitude,year,month,day,strTime,speed_mps)
             gpx_file.write(track_point_data)
             if speed_kph>maxSpeed:
               maxSpeed=speed_kph
               maxTime=strTime
             #print(" ".join("{:02x}".format(c) for c in unknown)+' ' +s+' '+'{0:.2f}km/h'.format(speed))
             break
        mm.close()
        gpx_file.write(track_desc.format(maxSpeed,maxTime))
        gpx_file.write(track_end)
        gpx_file.close()
        print("Max Speed:{:.2f}km/h".format(maxSpeed))
        print("Time:"+str(maxTime))
Fiddlerwithnoroof
Poland
Hi there.
I used your script to successfully export track from my LS470W recordings.
Had to remove last break from the innermost loop (without this change it exported only one reading per second while the cam stores 10 entries - from the whole second - at once). And I raised a bit the buffer length because the cam stores 10 entries, 32 bytes each, so I was afraid of underruns in case of 400-byte buffer.
There is only one issue (which for now I walkaround by converting the file to csv and resorting it in a spreadsheet but that's a crappy solution) - the entries from each second are sorted in reverse order. So you get, for example, 10:00:02, 10:00:01.9, 10:00:01.8 [...] 10:00:01.1, 10:00:03, 10:00:02.9 and so on. So in order to get the entries in proper order it'd be better not to write to the file on the fly but rather build a list, sort it and write it out afterwards.
BTW, some of the unknowns must be acceleration values (the dodplayer shows them so they must be encoded as well).
halinh88
Hanoi
Viet Nam
Hi, can you write a program that insert the gps data to other mov files
