What will make all the difference there is to grab a hair drier and heat it up.
My personal quick solution is THIS ONE because I know technique. Has attached / detached 100-s of adhesive-taped dashcams.
Of course everyone can decide what is best for him, but the proper technique is described in this thread video tutorial.
The plastic spatula wedge tool is nice, .
the string can hurt your finger(s) a bit
I don't bother with the string. I just use a plastic panel tool. Slide underneath and wiggle left and right. Up and down and it starts popping off.
But personally, I'm not a fan on this 3M tape. It's not black, at least not true black. It's more of a brownish/grayish shade. So when it's on the windshield, it sticks out like a sore thumb.
That's my complaint about it.
I used a plastic flat end trim tool, and it worked perfectly. Nice tip! Thanks @nikoMy personal quick solution is THIS ONE because I know technique. Has attached / detached 100-s of adhesive-taped dashcams.
That would be problematic for those that took that approachWhen I first tried to remove adhesive mount, I used plastic knife but it broke.![]()
3M VHB is held in place via surface tension. There is no "glue" like the fake stuff uses. (Fake stuff is the true nightmare one to remove)
The authentic 3M VHB adhesive tape is defiantly the perfect chemical balance. Strong long term bond but not impossible to remove.
using the fakes with adhesive.Where would we be without it?![]()
