Sadly i doubt anyone can make anything out of a low resolution CCTV footage like that, google is working on something interesting in this regard, but its only in their labs.
Sadly you cant enhance footage like you see in TV programs, or that is maybe google is changing that. https://www.engadget.com/2017/02/07/google-ai-image-enhancement/
You might find some help in this thread: https://dashcamtalk.com/forum/threa...h-more-details-from-night-video-footage.8255/
While it's mostly about night footage, some of the links in that thread will show you how almost any image can be enhanced to obtain given qualities you want (like sharpness or brightness), but there are limits which even the best technology cannot overcome. There must be something there to work with to apply these methods to successfully
This is why it is important to start with the best image you can capture, and that is where all cheap or low-spec cams fail
Most of the enhancing stuff you see on TV is absolute BS.
...but it is actually possible to significantly enhance an image by stacking video frames together which averages them out and improves the SNR. The camera and subject needs to be perfectly still on every frame for best results.
Its mainly used for astrophotography but can also be used for terrestrial objects. FBI with the help of NASA used the same enhancing technology to identify the backpack in the Atlanta bombings through crappy video footage.
For example, i have the same HIKvision camera as OP:
Single frame
vs 900 frames stacked (37 seconds of video - 24fps)
Longer video = more data/signal = better quality
@sanad if you can give me the raw video from the screenshot angle, theres a good chance i can enhance it for you
There is Video Cleaner, forensic video enhancement software created for law enforcement, and now available to everyone. It's free and includes support. http://videocleaner.com/index.html
PROBLEM......................................................................SOLUTION
Video details appear fuzzy............................................... MAIN - Unsharpen strength
Video details are compressed.......................................... MAIN - Video Contrast strength
Video colors are compressed........................................... MAIN - Color Contrast strength
Video colors are too subtle............................................... MAIN - Color Amplifier strength
Distracting flashing emergency lights............................... MAIN - HotSpot Suppression Video appears extremely dark or overly bright................. MAIN - Automatic histogram Distant details are lost in the darker areas....................... MAIN - Backlight compensation
Video is cluttered with tiny random specks....................... MAIN - Denoise Portions of the scene are out of focus.............................. MAIN - Deblur Lens Scene is too dark or too bright......................................... MAIN - CURVE
Scene looks like a mosaic of tiny squares........................ MAIN - DEBLOCKING Video contains repeated frames....................................... PROPERTIES - DUPLICATE removal
Audio is too quiet or shouldn't exist................................... PROPERTIES - CORE - Volume
Video plays at the incorrect speed................................... PROPERTIES - CORE - FPS speed Only need a range of video frames................................... PROPERTIES - CORE - Starting & Keep frame Fast moving objects look jagged...................................... PROPERTIES - FIELDS - Sep/Swap
Video jerks up/down or left/right....................................... PROPERTIES - FIELDS - Nudge & Shift Only a small portion of the video matters......................... PROPERTIES - CROP
Video is the incorrect size or perspective......................... PROPERTIES - RESIZE License plate or facial details are too small...................... PROPERTIES - RESIZE - SuperResolution
Video needs to be flipped or rotated................................. PROPERTIES - ANGLE
Certain color channels contain greater noise................... PROPERTIES - CHANNELS
Hard to detect when objects/people are moving.............. SPECIALTY - PRO - Motion Filter
Only want to examine complete frames (iFrames)........... SPECIALTY - PRO - iFrames Unwanted on-screen timestamp or logo........................... SPECIALTY - PRO - Remove timestamp/logo
Digitized video tape shows VHS aging defects................. SPECIALTY - VHS Correct fish-eyeand pin-cushionlens distortion.......... SPECIALTY - LENS
Camera perspective needs to be repositioned................. SPECIALTY - VIEW Can't read stationary signage or license plate....... SPECIALTY - AMPLIFY - Frame Radius
Movement or color changes are too faint.......................... SPECIALTY - AMPLIFY - Color Multiplier
Video overall color is incorrect.......................................... FINALIZING - COLORIZE Need to highlight a specific area....................................... FINALIZING - ACCENT Need to add on-screen text.............................................. FINALIZING - TEXT
Need to add frame numbers............................................. FINALIZING - NUMBER Need to add timestamp or time counter............................... FINALIZING - TIMEstamp
Need to know which settings are active............................ MAIN - List all active features
See what the enhanced version has changed.................. MAIN - All frames / mid frames / subtract
Need to quickly toggle enhanced-unenhanced................. MAIN - Deactivate all enhancements
Need to compare enhanced to unenhanced..................... MAIN - Compare Original to Enhanced
