How is he working at auto shop and not know how to drive a stick shift?? People who works in any kind of auto shop is expected to know how to drive any kind of cars so maybe he lied on job application?
Don't understand why they come up with all these different systems to make it difficult to select reverse, none of them actually prevents you doing it when you shouldn't!i was a mechanic in the used car dept at a toyota dealer for quite a while so i got to drive a lot of different stuff. to get into reverse, there are some where you have to lift a ring, pull up on the entire shifter, push it down into the floor, or in the case of my tacoma and some other toyota 6-speeds (celica GTS/matrix/corolla XRS to name a few), slam it hard left from center-neutral to get past the safety spring (R is to the left of first). i had to teach several customers that it was normal to require that much effort to get into reverse because they don't want you to accidentally do it while driving.
but yeah, this guy just didn't know how to work a clutch.
and actually now that i think about it, they never asked me if i could drive stick before i started working there. i could, but not perfectly, as i'd only ever driven a couple of friends' cars that were stick. i didn't buy my own manual trans car till a year or so later.
You haven't been trying hard enough!There is no way it will actually go into reverse while moving
More than 4mph forward there is no way, but maybe some have synchromesh on reverse? That would explain the need for the pull/push/whatever mechanism, although of course it doesn't prevent you doing it...You haven't been trying hard enough!
I'm sure there are people out there who've been up to the challenge. I've heard about engines being wrecked by selecting reverse while moving. Can't be pretty.
I'll Stick To The Cycle Lanes - It's Safer | Interesting Dash Cam Videos (not recorded by you) | 8 |
Similar threads |
