You could just wire it to your cars fuse panel, and pick a fuse that only becomes live when the ignition is on?
You can set the camera to turn off when power is cut, which is what will happen when you turn the ignition off.
Why would anyone want to do this? They could just plug the mobius into a USB adapter and then their normal lighter socket...
I DO have this setup. And it was a requirement to me. I wanted to make the thing look as much as possible as part of the car and working in a set and forget fashion.
I've used one of the spare fusebox positions for this kind of purpose. Hide a 3m USB under the head linning and through Pillar A into a 12v to USB adapter.
This way I don't have to remember to record. I just turn the key on and the mobius does it's job.
Well, now I know why someone would do this. I would still take it one further and wire it into a live-after-car-off-fuse for parking purposes.
Wait, you're not using the USB adapter/cigarette lighter 3M cable combo? There is no way to void a warranty that way and definitely not hard wired. I'm thinking midnight run that thing, get er done and in the morning no cables will be showing, so out of sight out of getting your butt kicked.Well, now I know why someone would do this. I would still take it one further and wire it into a live-after-car-off-fuse for parking purposes.
My wife is too afraid to upset the warranty on our new SUV that I am "not allowed" to hard wire anything. So I am making do with a Anker external battery that powers both mobius' while I drive (as it also recharges) and then gives power to both mobius' when the power is cut. I still have to pull both usbs out at the end of the day, let the Anker turn off (there's no off just on button), then plug both back in or the battery will be drained. Would be so much simpler if the Queen allowed her peasant to hard wire...
@xreyuk Sorry if I doubted the advice I just couldn't see it until Hangas opened my eyes
Removing in an accident isn't important, making sure you have clean underwear is.Its the wire to the fuse box (taped or not) "What if we get in an accident and you cant?
Btw- the usb cables are all hidden in the roof lining and door mouldings etc. I dont pull them from the mobius, I pull them from the external battery, usually only 1x a day.
Mobius>>usb>>usb extension>>external battery
External battery>>usb adapter>>cig lighter
-external battery+hard wire= no win
What is this 3m magic?
I dont know how thats "better". I ran it that way before buying the external battery. Unfortunately for any sort of realistic parking mode (MD in this case) the mobius battery life is just way too short, thus the external battery. So the battery powers 2 mobius', while being charged by the cig lighter when the car is on. When off it just power the mobius for md/parking mode, back on it charges...repeat till end of day when I need to pull 2 wires for 1 minute and then plug them in again to turn off the external. Not really a big deal, just less convenient then having them hard wired.Mobius>>usb>>usb extension>>usb adapter>>cig lighter is better. That's how most of us are running.
Maybe when the external battery dies, which will be prematurely since using pass-through all the time will kill it faster, I will hard wire it and just not tell the Queen.
depends how much they know about cars, you know, like when you need new tires, but the rims need replacing at the same time
Theres a step by step guide a guy has posted on the ford forums here in UK
http://www.fordownersclub.com/forums/tutorials/article/229-dash-cam-hard-wiring-mobius-actioncam/
Not sure if you have to sign up to view, gives an idea what you need to do though
