Correct, it is set to record in 3 minute segments but it is also set for auto shut-off after 3 minutes. Is there something I am misunderstanding? (A frequent occurrence)It sounds like you've set your unit to record in 3 minute segments. However it only records whilst the ignition is on and if you switch off it will shut down after saving up to that point.
That makes sense. I remember in the past setting a camera to run for a couple of minutes after switch-off but I think that was probably a different camera. (It's an age thing.)I think the auto shut-off refers to the screen time-out whilst driving. Not sure otherwise.
...but it is also set for auto shut-off after 3 minutes. Is there something I am misunderstanding? (A frequent occurrence)
