spotnz
hi all,
Having had my Panorama II for a couple of months, I've come up with a few items that I'd like to see changed or improved upon. Before the next model appears.
In random order
- currently the GPS display displays the speed to 2 decimal places. Is this overly accurate? I suspect that rounding off to the nearest kilometre would suffice.
- have the GPS recordings capture the Height in metres ( or imperial for those who desire it ) above Sea Level.
- allow Times set manually to overwrite the GPS settings, even after the unit is switched off & on again.
- do the GPS co-ordinates need to be recorded to 6 decimal places?
- What use do the X, Y & Z values have in practice?
- allowing the choice between speed in Km & imperial measurements
- being able to retrofit filters to a Panorama II.
- being able to use a UV filter. I know that CPL are important during daytime. BUT from my casual observations they're somewhat problematic during heavily overcast and/or rainy weather. At which times a UV filter is an improvement on filterless.
- Being able to able to choose the filters I want fitted. So that I can quickly change them when damaged, or weather conditions require it. Being able to source on from our local camera shop, for me, is more desirable & quicker than internet ordering.
- proper translation of the manuals. Whilst they're respectable & much better than the 2 chinese dashcam manuals I've seen. They are distinctly Korean translated directly into English. Which make for comprehension difficulties. EG the manual for the Constant Power Cable is in English, but for me undecipherable. Both are not the same quality as the DVR.
- proper “printing” of the manuals. the Panorama II manual looks like it was printed on a hi-res dot-matrix printer. Rather than a ink-jet or laser printer, which would be considerably clearer & easier to read.
- Supplying the Constant Power Cable manual as a proper PDF. The version I got from shpkorea had ALL 6 physical pages squashed onto one PDF page. & therefore unprintable. Before anyone asks, I did point this out to him, which was time wasted, as he didn’t think that there was a problem.
In producing this, I’m trying to get improvements made to ensure that these units as as good as they can be. & keep ahead of the competition.
your thoughts & ideas on these are solicited & appreciated.
thanks in advance
david
In random order
thanks in advance
david
