old4570
- Jun 11, 2015
- Australia
- Front: 70MAI , Ausdom A261, Mini 0826 , Rear: A118c
My test rig !
Both Current and output voltage are adjustable ..
My mission should I accept it :
To explore how little current / voltage will induce dashcam failure .. ( Failure to run )
In other words , how low will they run ... ( Voltage / current )
The input voltage range is some what broad , I may go with a larger battery ... ( If needed )
Unfortunately the LED display does not show with flash photography ..
SO I have fitted a Lead , hot glued in place to support the wires ( de stress )
Also fitted a Mini USB lead to the output side , also hot glued ...
I have a nice little mobile testing rig !
I am thinking the mini power supply needs to be in a case ...
