Hello All
Thanks to this forum I purchased an 0803 with GPS 3 weeks ago.
Unfortunately the recording is tempermental. Sometimes it records fully on the 3 minute recycle but other times it records for maybe 12 or 52 or 75 seconds and then there is a break before the next recording cycle cuts in (so I would be missing parts of a trip).
There is no consistency in the fault i.e. the trip might start out fine and then the intermittent recordings might kick in after 30 minutes, othertimes the intermittent-ness might be at the start or end of a trip with no issues with the recordings in between.
The camera gives a beep when ever the recording cuts out and the constant blue led light comes on.
I used the paper trick to make the fitting in the mount more secure as it was a small bit loose, however that has not fixed the issue.
The card is a 16gb Samsung (not sure of the class though) that came with the unit, there is no internal memory.
My settings are as follows:
Resolution: 2304*1296 30P 16:9
Quality: Fine
AE Meter: Center
WDR: On
LDWS: Off
LDWS: N/a
Flicker: Auto
White Balance: Auto
EV: 0
Recycle 3 Mins
Motion: Off
Auto Power: Off
Power Off: Off
G Sensor: 3G
G Sensor Calibration: No
GPS: On
Software: FW20140611 V1.0
Thanks in advance.
Quality: Fine
AE Meter: Center
WDR: On
LDWS: Off
LDWS: N/a
Flicker: Auto
White Balance: Auto
EV: 0
Recycle 3 Mins
Motion: Off
Auto Power: Off
Power Off: Off
G Sensor: 3G
GPS: On
Thanks in advance.
