mr_milo
- Jul 29, 2014
- Mini 0803 (Front) Mobius (Rear)
Will do! I should be getting it on Monday so by Tuesday or Wednesday I hope to have some results.
Thanks, I'll bear that in mind 🙂If you're going to print screen and post it here - you need to know that .jpg is a lossy format, meaning it will look a bit worse than what you were seeing, save it as a .png instead.
I'm not sure it's really worth worrying about since the MPEG video compression will already have thrown away everything that normal JPG compression will. Saving an image in jpg with a fairly low compression ratio should be indistinguishable.If you're going to print screen and post it here - you need to know that .jpg is a lossy format, meaning it will look a bit worse than what you were seeing, save it as a .png instead.
