sjakub
- May 4, 2014
- Canada
Hi,
I just bought a new SG9665GC, from amazon.ca.
It came with SG20160323.V2 firmware.
I am having some issues...
First is that when I cut off the power by disconnecting the camera, or turning off the car,
it turns off immediately and the file that was being recorded at that time is always corrupted
and cannot be played. I tried resetting it using the button on the side,
resetting menu to default settings, changing the "auto power off" option to different values.
I tried that using the car charger it came with, as well as a regular, desktop USB charger with a good cable.
Nothing helps.
The camera also resets the time to 2016-01-01 00:00 every time I turn it off and on.
Is there something wrong with it?
The other problem is that it looks like I have 4 pixels that are always white.
It's best seen when recording something dark.
I attached a screenshot (of that area) from a movie recorded when I covered the lens.
Those white pixels are always there and in the same spots.
Is there a way to fix those problems, or should I return it and get a replacement?
Thanks!
Nothing helps.
Thanks!
