ITB-100HD Versions 2.3 Firmware & 1.40 Player Available
Tiel
NYC
I just noticed ipassmall has posted a new v2.3 firmware for the ITB100-HD, located here:
http://ipassmall.co.kr/ipassblack/download_view.asp?bs=&pg=1&seq=121&sf=bSubject&ss=ITB-100HD
From what I can tell from a translated version of that page, you must also install the new PC Player version 1.40 to go with this firmware. The links are at the bottom of the same page.
Together, these updates appear to add another parking mode sensitivity setting, and address some unspecified bug fixes.
I'm still happily using firmware 2.1 which has been serving my needs well, but I would be interested in hearing any feedback on this latest update.
I don't have ITB100HD model, So I'm not sure it the same but i compare to change log on ITB100SPW (not HD or SP) it seem have improve more function such as LED, it have 3 mode, it can turn off , normal and simple mode and parking mode.
I download ITB100SP firmware but not flash yet but ITB100SPW already flash as i spoke.
Isn't there any English firmware which can support English voice prompt for ITB-100HD, ITB-100SPW, or ITB-200L?
[ITB-100HD] The firmware file.(Ver 2.3)We deeply thank you for favorite child pass the black series.Please feel free to download and use the attached file.
* Firmware Update Ver 1.4.0 to reinstall huen please use the dedicated PC player and sure.
Thank you.
[Major Changes]
Add sensitivity settings 1 parking mode entry- Added to the parking mode can be set via the Preferences menu entry sensitivity of dedicated PC player.If you set the "sensitive" because the high value of the speed sensor 3 anthem viewing based on the parking mode based onIs done more easily in most situations parking mode switch.
2 Other bug fixes
Thanks to everyone's posting, I updated from FW 2.1 to 2.3, Player 1.3.4 to 1.4.0, here are my findings:
1. Hoon Fart has two download links to Player 1.4.0 and they are identical, but the two links to FW 2.3 has different FW bin file, (1) has a slightly newer date as pointed out in Hoon Fart's post. I used the newer one.
2. Player 1.4.0 is all English without blank fields under English Windows. Shock Sensitivity renamed to Impact Sensitivity.
3. Parking Mode Setting added Parking Mode Entry Level with selections of Insensitive|Normal|Sensitive, not sure what exactly it try to address? to avoid recording traffic jam in Parking mode? 🙄
4. Message to Select a Viewer (previously blank under General Setting tab) has selection of Replay ON|OFF, what does this mean? Initially Player startup displayed this dialog box as posted in another thread, I played with it a few times and got rid of the dialog box.
Overall I like 2.3 better tho updated just 20 minutes ago 😀
Going to update today.
Any chance of a MPH version?
Thanks
Hi, downloaded the 2.3 fw for itb200hd and the pc player 1.40.Unable to save the fw to the sd card.Any help will be much appreiated.Thks.
No logical reason why, do you have access to a different PC you can try?
Any antivirus software that might be tripping it up?
I manage to save it to the sd card and did a reformat on the 1.40 player. After the reformat the set up file was not there.Unlike when i used the 2.1 fw even i do the reformat the
set up file is still there. Anything i do wrong?
Put the file after format. A successful formatting is always deleting all files.
enjoy,
Mtz
Mtz,i did that.Tried to do the setting on the PC player 1.4.0. "Set up file does not Exist"weird
enjoy,
Mtz
You can format the camera using your PC. Then copy the firmware file on the card. No need to use their program to format the card.
I have d/l the file but it's in bin formate. how do i go about d/l it and update into my cam?
Download List: http://ipassmall.co.kr/ipassblack/download_list.asp
Software
ITB HD BlackBox PC Player ver1.4.0.zip
English - 55.2MB.
24th June 2014
Information Page
http://ipassmall.co.kr/ipassblack/download_view.asp?bs=&pg=2&seq=109
Download Software
http://ipassmall.co.kr/ipassblack/down_proc.asp?filename=ITB HD BlackBox PC Player ver1.4.0.zip
For Models
ITB-1000HD
ITB-100HD
ITB-100HD SP
ITB-100SPW
ITB-200HD
ITB-250HD
ITB-200L
Worked fine for me on Windows 7 x64 so far.
Older versions except 1.0.0 would always freeze randomly for me, this current version has not but I have not used it a lot yet.
Firmware
2.3 firmware
30th June 2014
ITB-100HD(ver.2.3)(1).zip - 11.3MB
http://ipassmall.co.kr/ipassblack/down_proc.asp?filename=ITB-100HD(ver.2.3)(1).zip
I tested this and it worked fine, bitrate up to 6000kb/s
2.3 firmware
19th June 2014
ITB-100HD(ver.2.3).zip - 11.4MB (not listed on the website that I could find)
http://ipassmall.co.kr/ipassblack/down_proc.asp?filename=ITB-100HD(ver.2.3).zip
It both have documents included in the zip archive in Korean about how to update firmware and formatting SD cards.
Hi Hoon Fart,
Just wondering u still have the latest firmware and software? Try dwl from the above link but doesn't works. Having problem with my device and intend to reinstall. Thanks !
John
