Chriss
- May 23, 2015
- Singapore
Hi All,
I have been lurking around this forum and tried everything I can but my ITB100spw just couldn't work.
What is happening now ...
1) Unable to change any settings using PC player. Of all the tabs, I can only change the setting for the advanced tab. The rest all cannot!!
2) ITB100spw is supports to support 64Gb SD card. Bought a class 10 card. All is good except that after 2 days of recording, it will come out with SD card error on my dashcam. Apparently it was due to memory full. The dashcam doesn't seems able to overwrite the files.
and what I have done...
1) For the setting issue, I read that many have this problem. So what mostly did was to download Blackbox Player version 1.4.0 and pair it with firmware 1.1 . I tried it, delete the blackbox a couple of time, did firmware flash a couple of times also. It just doesn't allow me to change any setting, including the language. The only thing I am still able to change is the advance tab....
2) In order to make sure that the 64gb card I bought is good, I tried formatting the card using blackbox player. It still doesn't overwrite. I try download some formatting program as advised. Still cannot. I run check on my SD card. All good.
Can some pro out there give me advice on what else I should do or if I have missed out anything?
p/s: Don't ask me to exchange 1 for 1. I bought it off korea... gotta ship it back...
