A120412 said:I hope that my cars battery can deliver the consumption because sometimes if my car not running for two days the cam shuts down and the battery prevention led blinks. I think when my car is in the garage, I shut the cam manually off.
OK, I will send him a PM.A120412 said:Ask Apple CT for a good price ;-)
Mtz said:On 2013 01 09 itronics released a new firmware:
[ITB-500HD] firmware. (Ver 1. 1)
http://www.sendspace.com/file/xziqi1
Google translate:
1 Playback functions
Navigation through linkage video playback and preferences can be changed
Available after purchase - Remote Control + IR sensor + AV Cable
enjoy,
Mtz
Mtz, how did you find this new firmware or got notified about it? I'm wondering if there's any way to keep an eye on the updates for the ITB500HD firmware. Right now everything seems to be working pretty good apart from the 0.7-1.0s seconds delay between the sound and video.
mituc said:I have a few videos but the quality of the ITB100 should be better (more FPS, 1080p instead of 720p). However, to me these DVRs are surveillance equipment not entertainment gadgets, so it's more important to have as much usable data as possible in case of an event rather than having pretty much the same data but just at a higher resolution. For me it's important to catch the license plate of some car that I need to report or the face of the villain who scratched my car or some car from in front/behind mine, catching bugs disintegrating on the windshield at high speeds is nice but not necessarily useful (it just increases the need for larger SD cards for now). I think the only benefit I could use (and I'd really like) from 1080p and higher FPS is catching the license plate numbers from a higher distance when moving, and even when the image is almost static. For 6-7 meters when traveling with 50+Kmph is ok.
So here is a link with the player again:
http://www.fileconvoy.com/dfl.php?id=gd ... b05a1056fb
This is a free file sharing site so the file will be there 7 days starting from now.
Audio Video Capture Server - (c) Texas Instruments 2009
USAGE: ./av_server.out <option 1> <option 2> ...
Following options are supported,
Resolution options - only one should be specified at a time,
D1 : 720x480@30fps + 288x192@30fps capture mode
D1_D1 : 720x480@30fps + 720x480@30fps + 288x192@30fps capture mode
720P :1280x720@30fps + 320x192@30fps capture mode
720P_720P :1280x720@30fps + 1280x720@15fps + 320x192@15fps capture mode
720P_720P_30 :1280x720@30fps + 1280x720 @ 30fps + 320x192 @ 30fps capture mode
720P_VGA :1280x720@30fps + 640x352 @ 15fps + 320x192 @ 15fps capture mode
720P_VGA_30 :1280x720@30fps + 640x352 @ 30fps + 320x192 @ 30fps capture mode
SXVGA :1280x960@30fps + 256x192@30fps capture mode
1080P :1920x1080@30fps + 320x192@30fps capture mode
Feature options - frame-rates may reduce depending on options enabled,
AUDIO : AUDIO parameter Sample Rate to be followed after this (8000 or 16000)
LDC : Lens distortion correction is ENABLED
FD : Face detection is ENABLED
VS : Video Stabilization is ENABLED
SNF : Spatial Noise Filter is ENABLED
TNF : Temporal Noise Filter is ENABLED
AEWB : AE/AWB/AEWB is ENABLED
<2A VENDOR> : NONE2A/APPRO2A/TI2A to be selected based on the vendor for 2A algorithm
VNFDEMO : This will put the 2A to high gain for increased noise and APPRO2A needs to be selected
DEMO : If D1_D1 is selected this will switch off LDC, VS, SNF, TNF for second stream
GBCE : Dynamic Range Enhancement is ENABLED
WIN : Window Mode is ENABLED
RTSP : RTSP network streaming is ENABLED
FLIPH : Flip in H direction is ENABLED
FLIPV : Flip in V direction is ENABLED
OSD : Software OSD is ENABLED
<PLATFORM> : DM365/DM368 to be slected based on the platform chip
Codec options,
H264 <bitrate> <rcType> <preset>: H264 compression is ENABLED
with bitrate = <bitrate>, rcType = CBR or VBR or VBR, preset = AUTO or CUSTOM
MPEG4 <bitrate> <rcType> <preset>: MPEG4 compression is ENABLED
MJPEG <qvalue> : MJPEG compression is ENABLED
with quality = <qvalue>
Note,
- The options can be specified in any order
- Any option can be omited in which case default action is used
Example,
Example 1. # ./av_server.out DM365 AUDIO 8000 D1 AEWB TI2A H264 3000000 VBR AUTO RTSP
Example 2. # ./av_server.out DM365 AUDIO 8000 720P AEWB TI2A LDC TNF KNF FD OSD H264 3000000 VBR AUTO RTSP
D1_D1
SXGA
1080P
720P_VGA
720P_VGA_30
720P_720P
720P_720P_30
720P
VNFDEMO
NONE2A
APPRO2A
TI2A
KTNC2A
GBCE
DM365
DM368
DEMO
AUDIO
H264
MPEG4
MJPEG
AEWB
RTSP
FLIPH
FLIPV
MENUOFF
GSENSOR
GAIN
DISPLAY
