K2000 not working after 2 months
half assed
South Florida
So I bought a K2000 about 2 months ago. Worked fine until about a week ago. It wouldn't turn on right away when I plugged it in, but after a few minutes with the red light on it would switch to blue/red and begin recording as normal. This happened about 3-4 times in a row. Now it doesn't want to turn on even plugged in. I have left it plugged in well over an hour.
I think the battery is toast. What do you guys think? Time to buy something else?
Hi half assed,
I believe the camera should be able to work without the battery. Sounds like it might be a different problem.
damn. I tried not to leave it in the sun. I suppose it got cooked.
I'm building a mount for my Sony DSC WX100 and try that as a dash cam. If it doesn't, I'll probably save for a GoPro Hero 2. :mrgreen:
GoPro is a great sport cam, I wouldn't want one is a dash cam though, it's just not designed with that use in mind, not knocking GoPro product at all, it's just not the intended application
Neither is my Sony. I've never used a GoPro, but I have read they are super reliable and the Hero 2 & 3 have excellent video quality. Many motorcycle riders use them to record while they ride. Plus it could more useful than a dash cam for other video purposes.
I'm reluctant at this point to drop $150+ on a "good" chinese dvr. 8-)
what I mean by designed for purpose is that a proper dash cam does things like record when powered up from the vehicle, does data logging etc, if your usage is just casual then a GoPro might suit your needs, a cam that might get removed for other uses or that needs manual interaction to get it going or needs to be taken off every time you park somewhere is not really a dash cam that's going to be there when needed
having bought a lemon product though obviously doesn't help you think positively about the product
tested out my sony dsc-wx100 camera today. I love the video quality. :D
The video seems a bit wavy, even when you are not moving.
That's the good old rolling shutter effect kicking in. CMOS sensors are notorious for it! Some are better than others, though. The wavyness in this video will be from the vibration of the engine in turn vibrating the camera, and because of the way CMOS sensors scan line by line, the vibration translates to wobbly video. Sudden turns left or right would result in vertical lines or objects being skewed.
I would have thought his vibration issues were related to his subwoofers, it sure sounds that may, no wobbling when the music stopped toward the end
Ha! Yes, quite likely... I didn't even know there was significant bass as I was only listening low volume on netbook speakers...
Yeah 4 12s will really shake the camera :lol:
The mount I built is not very stiff either, but I'm sure it would rattle the same until I turn the music off which ain't happening. :D
Night test I took last night: I was impressed with the night quality.
here is the mount that I made for it really quick.
It is hard to use this cam as a dash cam as the battery only lasts about 45 mins recording HD video, but I will look into some type of charger for it that will work in my car.
i222.photobucket.com_albums_dd25_0778drz110_A94F2ACD_5691_4BEA99878c26dc98b9d7591d9d138ab2b0ba.jpg
i222.photobucket.com_albums_dd25_0778drz110_7F30BE62_62AD_454A899f38f73492ab3abf7b847d87967549.jpg
That mount is a serious safety hazard. How is it secured?
Does your car have airbags?
If you're ever in an accident, you or your passenger might have that mount flying into your face.
you can actually get cam mounts with the screw fitting to suit the bottom of your camera
reminds me of the very first cam cam (of sorts) I ever saw, I was in St Petersburg Russia about 5 years ago and my taxi driver had a Sony Camcorder mounted to the dash and hard wired in, he manually hit record at the start of every journey and recorded every trip, he was sick of fighting over who was in the wrong in accidents and all the corruption that goes along with it
I made it with some stuff I had laying around just to see if this camera would even work well enough. It's secured with velcro. I agree it could be a safety hazard though. The airbag is mounted below the edge of the dash, btw. I plan to remove this as soon as I come up with a better solution that doesn't ruin my dash and doesn't mount to the windshield. Anything mounted to the windshield is illegal in Florida except for rear view mirrors, ez passes, and GPS units.
I realized that, but that requires me to buy one. Why buy one and then this camera turns out to suck? It would be a waste of money. All I needed was a 1/4"-20 bolt with a tab to secure it for $1.
is that just a Florida thing? is it related to blocking field of view or some other reason do you know?
seems an odd rule if nothing to do with blocking field of view, a windscreen mount would be a lot safer than your big metal strap I would have thought, anyway, rules are rules
what I meant was once you had decided if it would work for your situation is that you can get professional mounts with the screw fitting, given the 4 x 12's you've got banging away there I thought you'd be needing something solid, just making a suggestion
