GPak
This thread is the third one in a series of alternative parking batteries for dash cams.
Coming from these two threads, on ‘Power Stations for Parking’ and ‘LTO Battery for Parking’.
https://dashcamtalk.com/forum/threa...-dedicated-options-extra-functionality.49972/
https://dashcamtalk.com/forum/threads/lto-lithium-titanate-oxide-–-the-ultimate-battery-for-dash-cam-parking-recording-diy.50484/
I believe, we should not rely on car's starter battery to power dash cam in parking mode, stressing it with a constantly undercharged state, and sooner or later it will fail to start the car at the most crucial moment because of that.
Hence dedicated parking battery is ‘must’ in my book, perhaps with exception when the parking duration is short enough and/or daily driving is long enough.
I also must say, that the use of suitable LFP based Power Station is the simplest, the most affordable and probably the best option available for a Parking Battery.
It is safe, full of functionality and very easy “Plug and Play” installation.
Now,
After building couple of LTO Batteries the question is why LFP (LiFePo4)? The simple answer is a slight advantage in size and cost, but otherwise LTO is superior to LFP in every other aspects.
LFP chemistry has higher than LTO energy density, hence for the same battery capacity it will have less volume/weight, not by much, but still.
At the same time, LFP is safe enough, and is not far behind LTO in this regard.
So if the sub-freezing charging or very high rate of the charge is not ‘must have’, but smaller battery size is important, then LFP is preferred choice.
Here are some images showing the difference in size between the roughly equal capacity LTO/184Wh and LFP/192Wh batteries, (LFP is black).
They both are 145mm wide 250mm long (5.7” x 10”), the difference is in height, 54 mm for LFP vs 82mm for LTO. (LFP height is less by 28mm or 1.1”)
To be continued.
Now,
To be continued.
