LS300W Firmware 20130326 update not possible > rename file
Gardi
Germany
hello from germany,
I want to update my cam DOD LS300W to the current firmware version.
many try, it did not work, It is not believed.
please help me
my Firmware is 20130326
i will update to this 20130328
I have the instructions and the firmware from the website Foxoffer.
sorry for my english
regards dirk
Re: DOD LS300W Firmware 20130326 update not possible ...28
I think you're better off waiting anyway, I have 1306130-SC-2 which is much newer and and it still has bugs that need to be fixed
thanks for reply,
I was of the opinion, that the 20130328 version is better as my 20130326
is the 1306130-SC-2 version a release candidate?
Gardi said:
thanks for reply,
I think they've changed the numbering convention recently from what I can work out, it's still buggy though, don't expect miracles in a slightly newer version
Please help me!
these instructions will not work, the camera always starts with the video recording
Download and decompress the firmware file (LS300W_130328.rar).
2. Please have the updated file to be copied to the root directory of your memory card.
3. Plug in the power, the Car DVR will automatically start. (If you boot from built-in battery, it may cause update failed by an electrical power outage.)
4. When you operate the machine, it will update automatically. With full grey screen in update progress, please wait for around 30s for its auto-reboot.
5. Press format or delete the firmware file from the memory card (avoid update loops). Update complete!
I have the following firmware for available > please see attachements
thanks for replay.
I just updated my GT300W to 201306180-SC-2. I now have LS300W Plus features: AWB, plate stamp and image rotation available.
Don't know if you want to try it on your LS300W?. Technically it should work but of course there are zero guarantees it will.
File is here if you're so inclined: https://www.dropbox.com/s/qxt1w9q8syz2fkb/FWA8S711.bin
Thanks for the note,
I would like to try. But, I did not get to update. The gray screen is not displayed, the camera immediately starts recording video.
I deleted all the data on the memory card an then only the firmware file (.bin) saved
not get ahead, why?
this is my problem
now I have made ​​a mistake?
my old original firmware from DOD was 20130326 and now have update, has worked with the following file
FW96650A
now I have not an DOD LS300W it is a GT300W with shadow recorder start-menu
the file FWA8S711 is not work, only this FW96650A.
why?
also my DOD LS300W have now follow resolution
1920Γ—1080@30fps
1280Γ—720 @ 60fps not there before
1280Γ—720 @ 30fps
848x480 16:9 @ 30fps WVGA not there before
640Γ—480@30fps
the Webcam function is no longer present
FW96650A
why?
I have that FW96650A version but never used it. The one I tried yesterday in the link above is named FWA8S711.bin and provides AWB, plate stamp and image rotation.
I can not install your version, unfortunately.
all .bin Files starting with FWA8xxxx will not be accepted.
I do not know why
I've done it πŸ™‚
I have to rename the file name, so simply.
now is my FW 201306180-SC-2
Thanks for that file naming test now we can understand how to use different firmware between the GT300W and LS300W.
Hi, do you know if this will work on my F10/SJ1000 ?
Re: LS300W Firmware 20130326 update not possible > rename fi
F10 different camera wont work.
I would not try it.
There was a post in the F10/SJ1000 thread about the latest firmware, if it didn't work for you try it on a different card formatted in camera.
Link to F10/SJ1000 firmware: http://wikisend.com/download/419864/FW96650A.bin
thanks for the reply. that link no longer references the correct file.
Has anyone downloaded the correct file? I would really appreciate it if I could download a copy. πŸ™‚
