wozzzzza
- Mar 12, 2013
- Australia
as soon as i picked up the CX-9 from the dealer, i drove out with a suction cap mounted dashcam to home. as soon as i drove i parked it, the first thing i did was start pulling it all apart to run wires and install the dashcam in it.
here is rear door where i ran the wires through the right hand cable duct
then carefully ran it through the headliner behind the air bags along the left side and across the top of the front left pillar to the camera.
the power wires i ran up the left pillar behind the airbag and along the top of windscreen under the roof lining.
wiring i tapped into the seat heater fuse for constant power as that will never get used where i am, and the cigarette lighter fuse for ignition signal
i took earth from a nice solid bolt and nut in there.
i also put a block terminal for any future wiring needs i can just screw the power wires and earth wires into it without having to go through much trouble with extra wiring.
the camera is mounted on the plastic mouldings behind the rear view mirror, fits nice and tight and out of view there, stealth install.
you can see i have installed extra wiring for 2 extra cameras i will place there shortly for testing purposes and redundancy, so will have 3 cameras in total once i pull them from other mazda that we still use a little bit.
thats pretty much it, quite easy install really.
