CyrDroid
- Jun 22, 2014
- United Kingdom
- Mini 0803
Does anyone have an issue with their Mini 0803 being slow to get a GPS fix?
Mine typically records no GPS information until around 12-15 minutes into the journey, after which it seems to work correctly. I ran it for a week of commuting and each journey to and from work suffered the same problem, so it's not just about getting an initial fix when the device is first used.
Another symptom is that if you leave the device powered on when the car is stationary, the GPS position wanders about. I left it parked for 15 minutes and according to the GPS data the car had wandered about in the neighbouring field, reaching speeds of up to 50mph according to Registrator Viewer 😀
After discussion with the seller (including reloading firmware) I returned it for a replacement and that appears to suffer the same problem. I've previously had two Mini 0801 car DVRs, both of which worked fine (GPS-wise at least, they both ended up returned for other reasons) mounted in the same location in the same car, so I don't believe there's an issue with where I'm locating it.
All connections appear to be sound - the camera plugs snugly into the mount and the micro-usb connection appears to fit well. I've checked the gps log files themselves (not just relied on RegistratorViewer being correct) and indeed the coordinates remain at zero until the time it gets its fix.
Attached is an example from Registrator Viewer of a typical journey - the blue speed line shows when the GPS starts to work.
Has anyone else experienced anything similar?
