Mini 0803 Hardwire Kit Compatability
ChiefWiggum
Mini 0803, B40/A118
Hi All & fellow 0803 fans!
My 0803 just arrived...but in my infinite brilliance I had ordered the Mini 0801 Hardwire kit (The info at the time gave me the impression that they were compatible, but they are not)
As I now know, the 0803 has micro USB and the 0801 has mini USB.
The hardwire kit I have got is mini USB for 0801.
Is it possible I can still use the 0801 hardwire kit by plugging a mini-micro adaptor ?
(The output power of the 0801 kit is 5V@3Amps, is this the same for the 0803 hardwire kit ?)
I could not find any power specifications for the 0803 kit, any one knows ?
Also, my Mini 0803 camera get pretty warm/hot when plugged into the cigaratte power socket.
Is this normal to be getting warm ?
you could buy an 0801 mount, an adapter would possibly work but I'm not a fan of multiple connectors if it can be avoided
onsell the one you bought and buy the correct one would probably minimise your losses
dear Chief,
as i know, most of the hardwire kits are only 1Amps or 1.5Amps. it maybe overstated to be 3Amps on your hardwire kit if it is normal.
the power requirement of mini 0803 is around 550mAh, so a 1Amps hardwire kit will work fine. 3 Amps one (if it is real) works also.
if you want to use a mini-micro adapter, you'd better choose one with the right angle, to avoid the cable stretch downward on your windshield.
Of course, a new 0801 GPS mount with miniUSB port also works. (you can order 0801 mount and 0803 hardwire kit this time, to fit two cars.......) 😉
0803 use Ambarella A7 chipset so the temperature is much higher than 0801, but the camera still works fine.
Dear Rayman,
Thanks for your advice.
I ordered a 3 meter micro USB cable from eBay and with the "old" 0801 hardwire powersupply, it works great !
The camera is also running at normal temperatures !(not hot at all, like when I tried the original cigarette power adaptor)
You maybe right about 3AMps in printed on it, it maybe delivering much less but enough to power the camera.
0803 is amazingly feature packed, I am loving it. Thanks again !
Same issue here, replacing 801 with 803. The existing mount is USB, new is micro USB. Since I already have the 801 (USB) mount wired, can't I just slide the 803 into the existing mount? Or is something different with the connection as well?
Yes, the mount connections are the same.
Official answer here
Missed that. Thanks! Great news.
