- Feb 5, 2015
- Sydney
- Australia
- VIOFO..DOD..
Mini 0807 menu functions and buttons.
Looking promising so far.
A bit surprised it doesn't have 1080p/60fps mode or resolutions higher than 1080p, but I normally only record in 1080p/30fps mode anyway so it's not too big deal.
Characteristic of the Sony image Sensor. Still has a reputation for producing solid day and night results. We'll see once we can get some side by side videos up.Looking promising so far.
Do you mean 0807 is using this model of Sony image sensor that doesn't support higher res than 1080p or 1080p/60fps?
If I am not wrong the Sony sensor in Xiaomi Yi action cam does support 1080p/60fps, so does that mean Yi's Sony sensor is better than 0807's Sony sensor?
Look forward to seeing some day and night comparisons with 0806. Not sure if I should wait any longer for 0807 or get something like 0806 that's already available.Characteristic of the Sony image Sensor. Still has a reputation for producing solid day and night results. We'll see once we can get some side by side videos up.
0807 is newer obviously and has had far more development than the 0806 did, other one that may be worth a look if you like this style is the 0826Look forward to seeing some day and night comparisons with 0806. Not sure if I should wait any longer for 0807 or get something like 0806 that's already available.
Cheers. I googled some info and I see the Sony IMX322 sensor is smaller at 6.23mm diagonally with maximum 30fps at 1080p, while Xiaomi Yi's Sony IMX206 sensor is larger at 7.77mm with maximum 60fps at 1080p.It's IMX322, it doesn't support 1080p60
Thanks for the info, I hadn't seen the 0826 so will look into it and come back to the 0807 when it's eventually released for my wife's car.0807 is newer obviously and has had far more development than the 0806 did, other one that may be worth a look if you like this style is the 0826
Good to know. I will take better low light performance over 1080p/60fps any day.that's why the IMX322 does much better in low light
Sample video already posted in this thread: http://dashcamtalk.com/forum/threads/my-twin-cam-mazda-3.16669/Do you have any vid by mini 0807 ? Can you post it ?
@Chris Hunt Do you have an update on when these will be available at your shop?
