VIIVIIIXIII
- Apr 25, 2013
- Canada
- ITB-100HD, SG9665GC, Mobius B & C2, T1, Z970WD
Mini 0826 Dashcam (1296P 30fps, with GPS and CPL filter) review
Thanks to Gearbest for supplying this unit.
Product link: Price: $74.99USD w/ free shipping
Coupon: GBMINI0826
Review:
The Mini 0826 (successor to the Mini 0806) is currently the newest offering in the Mini 08XX series, utilizing the same Ambarella A7LA50 chipset capable of recording videos in resolutions up to 1296p (30fps). It has all the features you would expect from a dashcam including: auto start/stop, seamless loop recording, GPS data stamping, time stamping, motion detection, wide viewing angle, etc.
The Mini 0826 has superb video recording capabilities in high resolutions such as 2560x1080p (30fps, 21:9 aspect ratio) and 2304x1296p (30fps) -- or 1920x1080 (45fps) and 1280x720p (60fps), if you prefer higher frame rates. Note that HDR function is only supported at 1080p resolution or below.
Initial impressions of the Mini 0826 (in comparison to the 0806) are that the 0826 is superior in regards to build quality as the body now has a rubberized coating giving it a more premium feel, whereas the 0806 used regular hard plastic. The 0826 is slightly larger than the 0806; the form factor may have been redesigned to eliminate heat issues commonly found across Mini series dashcams. The Mini 0826 only supports microSD cards up to 64GB, whereas the 0806 claimed to support up to 256GB (128GBx2). Other than that, the two cameras are extremely similar. Both Mini 0806 and 0826 use the same interchangeable slide mount.
*The initial batches of the Mini 0806 had some issues, and I have also read some complaints of bugged firmware even with the more recent units. I believe the manufacturer chose to end support for the Mini 0806 (due to poor reputation) and opted to create a 2nd version of the camera, hence the similar but tweaked specifications of both units.
At $74.99USD, I would definitely recommend the Mini 0826. It is a dashcam that does it all. Perfect form factor, great video quality, high resolution, tons of features, small price tag. The GPS module and CPL filter are not typically included with the Mini 0826. The only improvement I’d wish to see in the Mini 0826 would be a capacitor version for peace of mind in extreme weather. My Mini 0806 (since May 2015) hasn't had any issues yet so I’m not too concerned about the battery failing on me.
Currently, the Mini 0826 is cheaper than the Mini 0806.
Sample clips:
Original sample clips to be uploaded soon
Stock photos:
Specifications and feature list:
Box contents:
Coupon: GBMINI0826
Review:
Sample clips:
Stock photos:
![201512090925188208.jpg](/forum/proxy.php?image=http%3A%2F%2Fdes.gearbest.com%2Fuploads%2F2015%2F201512%2Fheditor%2F201512090925188208.jpg&hash=332af71358f54e730cc814936f4f20ec)
- Model: MINI 0826
- Type: HD Car DVR Recorder, Full HD Dashcam
- Chipset Name: Ambarella
- Chipset: Ambarella A7LA50
- Special Function: WDR, HDR, GPS, ADAS (LDWS, FCW, FCWD)
- Storage: Built-in 8GB internal memory
- Max External Card Supported: TF 64G (not included)
- Class Rating Requirements: Class 10 or Above
- Screen Size: 1.5inch
- Screen Type: TFT
- Battery type: Built-in
- Capacity: 330mAh
- Charge Way: Car charger, USB charge by PC
- Wide Angle: 135 degree wide angle lens
- Image Sensor: 3.2M pixel CMOS
- Video Format: MOV
- Video Resolution: 720P (1280 x 720), 1296P (2304 x 1296), 2560 x 1080, 1080P (1920 x 1080)
- Video System: PAL, NTSC
- Video Output: AV-OUT, HDMI
- Image Format: JPG
- Audio System: Built-in microphone/speaker (AAC)
- Exposure Compensation: +2, -2, 0
- White Balance Mode: Daylight, Auto, Tungsten, Fluorescent, Cloudy
- Language: English, Russian, Simplified Chinese
Box contents:
- 1 x Mini 0826 HD DVR,
- 1 x USB Cable,
- 1 x Lens Cleaning Cloth,
- 3 x 3M Sticker,
- 1 x Car Adapter,
- 1 x GPS mount,
- 1 x Film,
- 1 x CPL,
- 6 x Cable Clip
![201512090925198835.jpg](/forum/proxy.php?image=http%3A%2F%2Fdes.gearbest.com%2Fuploads%2F2015%2F201512%2Fheditor%2F201512090925198835.jpg&hash=516f9d43c850df723454d3872310fb8b)
