Hello petepete, I'm not sure exactly what you are saying with regard to NOT powering the 0806 via the base. What do you mean by the "base" but powering it via the port in the camera, what specific "port"? I thought that there is only one way to install the wiring to the camera and then to the "cig" power outlet, with the simple install.I would suggest to anyone who has one of these NOT to power it via the base ...
power it via the port in the camera.
you still get functioning gps as the power slips from the camera up to the base..
There IS method behind my madness
While the 0806 is undoubtedly a provider of very good footage, I have noticed on the 0805 I can read a sign hanging in my kitchen that cannot be read by an 0806 and have yet to start testing an 0805 in the car but that hints at the fact the 0805 might actually perform better ... I was surprised !
Have to say the new mini with re designed body and capacitor should shape up to be a "coming of age" mini with all the history before it and I would expect it to become the camera of choice for many ..
they're essentially the same bar the lens
The batteries on the 0806s will start to give up when the summer heat arrives next year, then you can have an upgrade! The batteries are only small so two summers is quite likely all they will manage. Of course you could replace the batteries cheaper than an upgrade.Sometimes not just more reliable, the difference between working and not !
Its can also be a neater install.
I would like to try one to confirm my suspicions..
but I cant justify buying one as my dam 0806 s seem to be reliable !!!!
When I had them side by side mate the 0806 was better at night so might be worth trying again tonight? The 0806 did give clearer night time footage than the 0805, they were early units though.
I've never noticed a difference once they are properly focused, wouldn't be surprised if they are all from the same manufacturer but just coated differently, it's the anti-reflection coatings that cause the colour.were the early lens on the 0806 that looked purple ish in colour better than the late ones ?
H | mini0806 sound crackles (noise) problem | Mini 0806 | 4 | |
Dual channels mini0806 - NEW mini0906 | Mini 0806 | 4 | ||
L | Mini0806 intermittently stops recording | Mini 0806 | 11 | |
S | Another 2x mini0806 bite the dust... | Mini 0806 | 5 | |
C | Need a second opinion. I think my mini0806 is out of focus | Mini 0806 | 2 |
