The SG9665GC uses a "public" casing which is the same as the A118/B40, etc., and this is one of the drawbacks to that approach but I think the newer V3 SG9665GC may have finally addressed this issue.
the V3 still had the same case, the SGGCX2 is our own housing and has this extra relief for the card
Jokiin, as a result of your post above I decided to take a look at your web site just now and you show the V3 case as having an indent on the memory slot. Why is that?
it does have that, always has had, the SGGCX2 has a much larger recess around the card
I'm a bit confused by your earlier post above where your said, "the V3 still had the same case, the SGGCX2 is our own housing and has this extra relief for the card". That sure sounds like the V3 doesn't have the indent.
I'm not sure about the miscommunication but I'm glad to see that it does have at least a smaller one. So my comment that the V3 may have addressed the issue was apparently indeed correct, I guess. Anyway, I always appreciate that you keep moving the bar upwards.
we didn't address anything in the V3, the indent it as is the same as V2 and V1, even the SG9665GM from 2013 had the same indent so I can't take credit for any changes
the new model though is definitely changed
Your right, it's been there all along, so my apologies. The little indent on one side of the slot is so useless I just never noticed it, especially from the perspective from the driver's seat. Again, happy to see the new design.
No prob for me, jus use fingernails to push the card in... Can't be that hard unless the fingers are very thick.
