Missing Minutes !!
152bobby
Wokingham
Thinkware Q200, 2CH, 256GB, OBD2/F200 2CH Pro/Vantrue E1 Pro
Hi,
On my daughters 2 channel Thinkware Q200, there seems to be minutes missing. I thought this would be recording every minute.
Just fitted a new Thinkware 128GB SD card.
See attached example of the recordings all on one journey and there are gaps.
I have the same Fashcam fitted and mine records every minute.
Have I got a setting wrong somewhere on hers ?
Is it possible the "missing minutes" are in a different file folder?
Like event, or emergency folder?
I'll have a deeper dive into the files. I thought if I just pick Front or Back or ALL, especially ALL, I'd see ALL πŸ˜‚
I think I will have to check each setting in my daughter's Dashcam against my settings and see if there's anything different.
Normally I only have her car for an hour or so to do the usual "Daddy Safety Checks" but I have it for a few days this time, so I'm sure I'll spot what's going on.
Cheers
Hi,
Hi there,
Have you tried checking the set privacy settings in the dash cam settings?
What is Privacy Recording​
Privacy Recording is a new feature that erases the SD card for your privacy, constantly looping over existing footage and storing only a limited-time backlog.
Make sure the set privacy recording is disabled https://support.thinkware.com/hc/en-us/articles/17547043200787-Set-Privacy-Recording
Cheers, I spotted that option and have turned it off, I'll check the footage again πŸ‘
Just done a test drive after changing this setting and its now recording every minute with no gaps. A thank you to our Thinkware friend in πŸ‡¨πŸ‡¦.
