I have used the Mobious dash cam and the reaview mirror stye dash cam.
The rear view mirror style /i am talking about is the one with 5 rectangle buttons along the bottom edge of the mirror. Only a forward view. I wish all of these cams had names like the Mobious. But even the Mobious does not have the version marked that I can see.
The colors of the Mobious cam are much better balanced than the rearview mirror style cam.
The Mobious dash cam colors are very balanced. Like red is red ,blue is blue etc.,.
The rearview mirror style cam has too much blue in all the video.
Like pavement is blue not black.
The rearview mirror style cam is easier to use because when you first start your vehicle it comes on.
If it does not come on then you just push the left hand ON button on the left side of the mirror.
When you want to stop the rearview mirror style dash cam ,you just push the off button. Easy.
With the Mobious on the suction cup mount, the image must be flipped in the(txt file for MAC users) and set up program for the PC users.
When you want to stop the Mobious cam you have to push the on/off button, but the cam is upside down in the suction cup front window mount and to get to the buttons you must take the cam off of the front window or figure out how to do it without knocking the cam off of the front window. Very difficult.
For motorcycle use the Mobious image will NOT have to be flipped.
I mounted mine on the wind shield at first and there was some glare but if you put it on your helmet then the wind will make noise on the video.
Maybe a foam over the cam sound port?
