nexus.sixx
- Sep 25, 2018
- United Kingdom
Mobius 2 - recording problem
Hi
I have been using a mobius 2 as a dash cam for a about 3 years (with a battery) without too many issues.
It recently stopped recording and after looking at the SD card on my PC it appeared to record ok but not save the last file
correctly which I put down as a failed battery issue so I just ordered and fitted a super capacitor but now have another issue.
The SD card is a recently purchased Sandisk Ultra 32GB class 10 bought from Amazon so should be genuine.
If I format the card using the in built camera routine and apply external power it powers up and records and
correctly saves the file when powered off so the new Super Cap must be working OK . If I run it for a period it records
multiple files and finally the last file all OK.
The problem is if I then power it up again after it has been used only once it does not then start recording. After the initial start up LEDS
the orange LED is steady showing it is in video mode 1 but on standby.
If I reformat the card it will go around the same loop as described above i.e record ok once only.
I have also reloaded the 2.14 firmware and tried a reset
The only thing I can think of is that it doesn't like the Sandisk SD card for some reason but it will record to it straight after formatting but only once.
Anyone got any ideas ??
thanks
Hi
thanks
