Looping. Will not over write oldest files.
What does it overwrite? I have always thought it was the oldest.
A newb and so lost when it comes to terms etc. I was so eager to get my Mobius (Wide Angle 1080p) and to start recording that I didn't do the proper background work when it came to microSD cards. I went to my local Wal-Mart and bought a SanDisk 64GB (red/grey) with a class 10 rating. I'm guessing this won't work on my camera based on the comments. Hopefully I can take this back and return it.
It will probably work fine, possibly even for quite a long period of time. The problem with these SanDisk cards is that they may fail unexpectedly when you least expect it.
First, thank you so much for taking the time to even respond and help. So keeping the SanDisk should be fine? I was going to try and return it today and buy a Kingston Digital 32GB Class 4 on Amazon.
You're welcome!
If you are able to return the SandDisk card, I would. Why use a card you need to worry might fail?
Amazon is an excellent place to purchase memory cards because you know you will be getting a genuine one. Just be sure it says "ships from and sold by Amazon.ca" on the sales page and use caution from sellers not using Amazon fulfillment.
Kingston and Transcend are good choices. I've never had any issues whatsoever using Class 10 cards in any of my Mobi.
Like @Dashmellow said, class 10 will work on Mobius. Class 4 is hard to find. I've no problem using Kingston Class 10.
What caused the Mobius case to warp - just the heat inside the car? Any pics to share?Today I noticed the Mobius case is warped (badly) so took it out to check the video.
And a new camera?So I guess I need a new card.
And a new camera?
Lexar 300x SDHC 32gb dont work inside my mobius.
It works computer, phone, camera but not inside mobius. When i connect mobius with my computer that card inside and opening msetup, then i dont see there that card, and also cant format. If i format with windows to FAT32 or exFat it does not work also.
Bought next some A-Data SDHC 16gb card to test and it works... (too bad i didnt bought 32gb)
Thanks for the software, it works nowYes, heat, it gets up to 45 C where I live. It did suffer a small amount of warping after a higher capacity replacement battery bulged, but it's now really obvious. (It's had a capacitor inside since the battery bulged.)
No, the Mobius appears to still be alive. The electronics appear to be tougher than the case!
I'm running a Lexar 300X in one of mine. I did have a lot of trouble getting it formatted and working, but can't recall the exact procedure I used. Have you tried using "SDFormatter"? https://www.sdcard.org/downloads/formatter_4/
Any pics to share?
Thanks for the software, it works now![]()
