I've had my mobius around 5 years or so and use a Super Capacitor and it will not record, I changed the card and it didn't make any difference. It lights up but does not have the yellow light blinking. Any suggestions?
Bob
Well I reformatted the card and this time its working. Several years ago I used a free program from this board to edit my video's but don't know what happened to it. What free programs are people using to edit?
Bob
I used to Registrator Viewer to edit my mobius videos but have been away from it for a couple of years and when I downloaded it I get the message "got meta data your request was forbidden" . Is it not working anymore?
Bob
Is that a built-in factory USB port? Those can cause problems for cams due to low power levels. If you're using a HWK or adapter-type PS it may be going bad.
Phil that was the problem, the factory usb port must not have enough power. I tried it in my car and it worked. I had it direct wired to the bike and the plug went bad so tried the usb port. I need to find where to buy a new wire.
Bob
Glad you've figured it out and that the cam is still good The original Mobius is probably the most durable and longest-lived cam of this sort ever made. It's very rare for them to fail entirely. Can't help with suggesting a PS but any decent one should work fine, as Mobius neither needs high current nor is it terribly picky about it's PS being 'clean'.
