MS Multi Saver Cut Off
AndySnapper
Bristol
There is another socket on this unit called '4 pin remote switch extension connector' in the manual.
Has anyone worked out what this is actually for and used it?
I was kind of hoping I might add a second camera (rear) to it instead of using an twin adapter in the supplied socket.
Cheers!
Andy
Cheers!
Andy
4-pin socket is for remote control button of BAT/ACC switch function, same button as on top of MS unit. To connect 2 dashcams you can buy cigarette lighter socket splitter. MS can handle up to 4 daschams with no problem.
Many thanks for that. Will use a splitter (shame about the extra bulk to hide).
Cheers!
Andy
