Apparently part of the motorcycle driving test in Texas is to make sure you can pick up your own bike. You have to lay it down on padding or grass or something (help is allowed here to prevent damage) then pick it up entirely by yourself. If you can't do it you fail.
Yeah, he was doing it wrong. It's very difficult to put a motorcycle back up by the handlebars, even a lighter one, not least because one's body isn't in the best position to apply all the force needed. It should always be with one hand in the handlebars and the other anywhere in the frame near the seat, when possible.amazing how many people don't even know how to correctly pickup a bike
I didn't mention them because they're usually too far back. The best place to apply lifting force is between the axles, so any place nearer the engine is always better.Protip: If there's a passenger seat there are usually passenger sidegrips.
That HD wasn't even completely down, it was only at a 45º angle, and the guy couldn't pick it up by himself. Either he's somewhat unexperienced or he should no longer be riding
FAIL! What if the bike is laying on the other side? They don't have a sidestand on the right! Most people would probably dump the bike on the other side if they try to lift it up as shown in the video.here you go, as with everything these days there's a how-to video on YouTube
I'm not sure I would flip it over to the side stand as shown, was just highlighting the actual lifting process, once you lift it to the balance point you can easily turn around, I worked in a motorcycle wrecking yard when I was a kid and even in my early teens could lift 1000cc bikes like this quite easilyFAIL! What if the bike is laying on the other side? They don't have a sidestand on the right! Most people would probably dump the bike on the other side if they try to lift it up as shown in the video.
You can control the balance much better once the bike is upright, if you're facing it.
NO Good Deed Goes Unpunished | Your Dash Cam Videos (recorded by you) | 2 | ||
No Good Deed Goes Unpunished | Your Dash Cam Videos (recorded by you) | 49 |
Similar threads |
