EDIT: Conclusion first, then details.
Conclusion (tl;dr)
The only viable MLC NAND options are the Transcend High Endurance line and the Kingston Industrial line. Transcend gives a 2 year warranty while Kingston gives a 5 year warranty, both with capacities up to 64GB (
https://www.amazon.com/gp/B01BDKTRAE for Transcend and
https://www.amazon.com/gp/B01DOFCPNW for Kingston). Note that Transcend and Panasonic are the only ones who claim Error Correcting Code (ECC)! If 64GB is enough for you (or all you can use), and reliability is paramount over saving a few bucks, then definitely go for either the Transcend High Endurance or the Kingston Industrial.
Otherwise, PNY and Lexar both make 128GB+ microSD cards that aren't MLC but also don't void your lifetime warranty if used in dash cams. So if you want larger sizes, the Lexar High Performance 633x series (
https://www.amazon.com/gp/B012PQKFNI) or PNY Elite series (
https://www.amazon.com/gp/B01G26R7LA) make the most sense, available in larger sizes and fairly affordable. Sure, neither are MLC, so they'll probably wear out faster, but at least when your card dies you'll probably get a replacement.
With due respect to
@AndrewL the Lexar 633x does not use MLC NAND despite rumors floating around the interwebs.
Details
Digging through a bunch of them, it appears many manufacturers are backing off MLC claims. Essentially if they brag about it as they should, then it's MLC. If they don't, it's TLC. If they claim they're mixed and can't guarantee it, then what they're guaranteeing is that none of it is MLC. No manufacturer is going to produce the much more expensive MLC and then toss it in the bargain bin with the TLC cards. It would be like a seafood provider choosing to mix in real high-dollar Deadliest Catch crab in with the imitation crab on purpose.
Note that Transcend voids its lifetime warranty for cards used in in-car video recording devices. So if warranty means anything to you, skip the Ultimate line and go for the High Endurance line. Panasonic only provides a 1-year warranty and is tied for Sony as the most wildly overpriced anyway. PNY doesn't offer MLC, but they do claim a lifetime warranty without explicitly excluding dash cams. Lexar doesn't offer MLC, and their High Endurance line is only warranted for 2 years. Same for Sandisk's High Endurance for Video Monitoring line, 2 years.
Clearly these manufacturers know how hard 1080p+ dash cams really are on cards, especially with the temperature extremes they see.
Transcend definitely claims MLC with ECC for their high endurance line, basically the gold standard for dash cams, with a 2 year warranty and capacity up to 64GB:
https://www.transcend-info.com/Products/No-727
They also claim MLC for their Ultimate line which also tops out at 64GB, such as in this PDF where they say nothing about it for the Premium line, meaning TLC, but their lifetime warranty is void in dash cams regardless, and you don't need the extra speed, so stick to the High Endurance:
https://www.transcend-info.com/products/images/modelpic/423/EN_microSD_ProductSheet.pdf
Warranty:
https://www.transcend-info.com/Warranty
Kingston claims MLC for their Industrial line, but they don't claim any kind of ECC. Capacity only goes up to 64GB. They offer a 5 year warranty, and thankfully that warranty is not voided by use in a dash cam:
http://www.kingston.com/us/flash/microsd_cards/sdcit
Warranty:
http://www.kingston.com/us/company/warranty
Sony claims MLC for their SR-UZA series, even showing a 128GB model. But they don't claim ECC, nothing is available on their product or support web sites on the warranty, and the 128GB model doesn't appear for sale anywhere, making 64GB the largest actually available. Amazon indicates a 5 year warranty with no indication of limitations, and these cards are still twice as expensive compared to all but Panasonic for no clear reason other than brand name. Skip these and run Transcend High Endurance or Kingston Industrial for MLC offerings:
http://www.sony.com/electronics/micro-sd-memory-cards/sr-uza-series
Panasonic offers quite a few "Consumer Plus" SD and microSD MLC choices as an offshoot of their industrial lines, in this case the TE series is the most appropriate. These are the real deal, and they include ECC. But they're only available in up to 64GB, only have a 1 year warranty, are tied with Sony for twice as expensive for no discernible reason, and they are not generally available on Amazon but instead only through Panasonic's own authorized resellers. Skip these and run Transcend High Endurance or Kingston Industrial for MLC offerings:
https://na.industrial.panasonic.com...mer-plus-sd-cards/series/te-series-mlc/CS4103
PNY doesn't claim MLC for any of their memory cards, but they do claim a lifetime warranty for their High Performance and Pro Elite cards that have been "installed, maintained and operated under conditions of normal use and in accordance with the installation guide provided herewith." But they don't provide an installation guide and don't say what normal use is, and it's only applicable while that particular product being manufactured, so no "equivalent" replacements are promised. YMMV.
http://www.pny.com/mega-consumer/shop-all-products/flash-memory-cards
Warranty:
http://www.pny.com/File Library/Support/PNY Products/Warranties/Flash Memory Cards/Micro-SD-Warranty-Class10.pdf
Lexar doesn't claim MLC for any of their cards, even their high endurance line. And they have a short warranty on those:
http://www.lexar.com/products/memor...ndurance-microSDHC-microSDXC-UHS-I-cards.html
That said, Lexar's High Performance 633x line, while not MLC, is available in higher capacities with a lifetime warranty that is not explicitly voided by use in dash cams which is nice:
http://www.lexar.com/products/memor...nce-633x-microSDHC-microSDXC-UHS-I-cards.html
Warranty:
http://www.lexar.com/content/dam/DAM_Lexar/lexar-family/warranties/lexar-global-warranty.pdf
Sandisk doesn't claim it for any memory card products, including high endurance lines, only some of their SSD's. They do have a special line for dashcams and surveillance systems, but they still void the warranty for dash cams:
https://www.sandisk.com/home/memory-cards/microsd-cards/high-endurance-microsd
DO NOT USE SANDISK ULTRA CARDS. It should go without saying at this point, but they're cheaper for a reason and have developed a very bad reputation in heavy use applications like dash cams.
Warranty:
https://www.sandisk.com/about/legal/warranty/warranty-united-states
Samsung's marketing team originally claimed it when they released their current lines, then then said whoops sorry about that it's only for Pro and Pro+, and now they don't even claim it for those. And the warranty drops if you use it in any kind of surveillance device, saying in their full specs, "Warranty is limited for any type of surveillance system." So...not good:
http://www.samsung.com/us/computing...ry_cards-microsd/_/n-10+11+hv22y+zq29p+trokt/
