Module 79L
- May 17, 2015
- Portugal
- AT11DA, SG9665XS, G1W-H
Thirteen working days after being sent, it arrived. Not bad, considering the time of the year and two weeks with only 3 working days each.
JooVuu's service was flawless. It was out of stock when I ordered it but he camera was "shipped" when Dan said it would, he always kept me posted on everything regarding the payment and answering any questions I had.
I was going to make an unbagging video but I thought "nah, it would never be as spectacular as an unboxing video", so I ditched the idea.![Roll eyes :rolleyes: :rolleyes:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f644.png)
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
One can never realize how small these things are until one has them in one's hands. I mean, I had a pretty good idea about the G1W's size but it still surprised me when I had them in front of me. This one, however, is far smaller than I could ever imagined. The Allen key, for example, how is it even possible to make an hexagonal key that's as thin as a needle? I hope I'll never have to re-focus the lens because I think any little force applied to that key will bend it straight away!
The capacitor pack is so small that I thought they forgot to send it, until I decided to re-check inside the padded envelope the camera came in and there it was!
Card formatting, firmware update, setup, getting acquainted with the LED's colors and color codes, and indoor testing, it's all done. It works with VLC in webcam mode, so I'll have a go at aiming it with my 12" work laptop.
Things I didn't "like" so much, which lead to the question's part:
1. The camera has to be mounted upside down, which means the heat sinks won't dissipate heat efficiently and there's a good chance the camera will get hotter because the heat will rise and stay inside the casing. I only recorded less than 30sec at a time during testing, on battery power, and the heat sinks got a little warm. I thought of 2 possible solutions:
A. Drill some holes on the back of the casing and the craddle to allow the heat to come out;
B. Cut a magnetic metal plate to fit the size of the heat sink. That would be screwed to the suction cup mount or I can make some sort of a metallic arm that could be fixed to the RVM's stem. Not only it would help dissipating the heat but also would be easier to remove the camera, in case I needed to.
Questions:
A. I know the casing isn't weather proof but can some extra holes be a problem when you think of how moist the air can become inside a car on wet days? I'm thinking about the periods of time when the camera isn't working.
B. Can a strong magnetic field affect the camera's work, especially when it'd be situated right above the processor?
2. The folder's name. I noticed it's 100HDDVR, so it doesn't seem to have any indication regarding the date of the files it contains. My other cameras all create a new folder each day, called 100, followed by the date. For instance, if they're recording past midnight, there will be two folders in the card, one called 100xxxxx and the other called 101xxxxx.
3. The file's names. I also noticed they only have a sequential number, no date.
Questions:
2. Does the Mobius only have this one folder and it stores all the files inside, no matter from what days they are?
3. Since I empty the card every day, will the first file of the next day be number 0001 again? Is there any way of changing the way the files are named when they're created?
Questions:
Questions:
