Adi Nistor
- Jan 31, 2016
- Romania
Hello all,
I just want to share with you the e-mail which I just sent to blackvue, with a list of suggestions:
I purchased recently DR750S-2ch and until now I'm very happy with it.
In order to demonstrate my gratitude, I gathered a set of suggestions which might make 750S even better![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
Here is the list, the order is random, i just put numbers for an easier tractability:
1.) Custom time for entering parking mode
- I would like to be able, from settings, to customize the 5 minutes time for entering parking mode after I stop my car. Personally I would try to something like 1...3 minutes.
2.) Mirror rear camera when visualizing front & rear recordings
- I would like to be able to see the rear camera mirrored horizontally, and I am not referring to the rotation. The reason is that when I play a recording and see the front camera as the big image, and the rear camera as a "picture in picture" frame, then the following situations (which I do not like) happens: If I look at my front camera recording to a car parked on the right side while I'm passing over it, the car will, of course, disappear from the front-camera recording in the right side and then it will appear immediately in the rear-camera-frame. The problem is: where will the car (parked on my right side) appear on the rear camera view ? -> in the left side
If I'm driving and I'm using the mirror to see that parked car, I will, of course, see it also in the right side, and this is what I would like to be able to see when I visualize both videos (front & rear) overlapped.
3.) Event limits
- Possibility to limit (eventually in percent) each category of recordings (M (manual recording), P (parking), E (event), N (normal) ). E.g.: I want to have events stored in maximum 10% of the SDcard. If this 10% disk space is reached, then the camera should start overlapping the oldest event videos.
4.) Connection from mobile to dr750s through a WiFi router
- I have a WiFi router (with a 3g/4g SIM) in my car so my blackvue camera is all the time connected to the internet and to cloud. I would like to be able to connect with my mobile phone to the same WiFi hotspot in my car (so both dr750s and my phone will be connected to the same wifi and have access to internet) and then to be able to connect my Android BlackVue app to my dr750s directly (not through the cloud because the connection speed is very uvery low) . It's not so nice that, in order to connect with my phone, I need to disconnect it from my wifi hotspot, connect to blackvue directly, then it means that I do not have internet anymore on my mobile (even if on my mobile I have 4G, it doesn't work because the mobile sees a wifi connection).
5.) Connect to cloud with both: windows app & android app for push notifications
- If I login to cloud from android app, and then I login also from Windows BlackVuew app by pressing "switch to cloud viewer" , then I'm disconnected from the mobile and I do not receive push notification until I manually log in back on my android phone. I would like to be able to login from both devices in parallel, eventually to receive a notification on the mobile that windows app was also connected to cloud.
6.) Windows viewer - combine consecutive videos
- BlackVue Windows App - See successive videos as a combined video ! It's ennoying to load one by one , minute by minute in order to search a specific situation in the images. I would prefer to have an option to "optimze video file list" in a way that when it's possible, videos are virtually combined . If I drive 2h and I have all 120 videos of those 2hours, I would like to see only 1 entry in the video list in the application. This would be one very important improvement.
7.) Windows viewer - full route
- BlackVue windows app - The possibility to see the entire route on map, [works good with the previous point of combining videos]. When you select a 2hours virtual video (combined from 120 successive 1 min videos) it would be nice to see also the entire path/route marked on the map.
8.) Windows viewer - speed graph.
- BlackVue windows app - I would like to see also a speed graphic, not only the graphs for acceleration sensors.
9.) Windows viewer - Enhanced charts
- BlackVue windows app - to be able to make the charts bigger (to be more visible) and to see the values on a specific point of the chart.
What do you think?
Would you "vote" for any of these suggestions?
Regards,
![Frown :( :(](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f641.png)
3.) Event limits
What do you think?
Regards,
