I experienced similar issues with my T130 however mine were tracked down to powering where I had an intermittent connection in my power socket.
As best I can tell the socket condition was present before I used it for the T-130, but the other cams which had used it weren't as sensitive to temporary power drops as the T-130 which does have a higher power requirement. On repairing the socket my problem went away, and I'm still using that socket for4 other cams successfully.
I'd recommend you very carefully inspect your powering scheme, giving all the fuses, wires, and connections a wiggle while the camera is running to see if this might also be your issue.
