- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
Yes it needs to be grounded to work
jokiin said:Yes it needs to be grounded to work
Hillbilly said:jokiin said:Yes it needs to be grounded to work
I hope you didnt just stuff a wire down beside a fuse and jam it in cos thats a recipe for disaster
would be better to get someone to install it properly, shoving a bared wire under a fuse is the recipe for disaster as mentionedGil said:I had to remove a portion of the wiring insulation and wrapped around one of the fuse pin's and pushed the fuse back in.
jokiin said:would be better to get someone to install it properly, shoving a bared wire under a fuse is the recipe for disaster as mentionedGil said:I had to remove a portion of the wiring insulation and wrapped around one of the fuse pin's and pushed the fuse back in.
Gil said:I followed this video :/
Gil said:
jokiin said:if your car uses the mini blade type fuse then yes that will work and that's a far safer solution, they do stick up a bit so just make sure your fusebox has enough clearance to allow it to fit with the cover on
You can buy fuses with a wire already soldered onto them and they dont have a piggyback one on them like the ones pictured in the linked thread.Gurkha9 said:I ordered the same thing from eBay. Will find out how it fits soon enough.
Luckily I have no fuses around the one I will be tapping into so I should be ok.
Only thing to check is the cover as I don't know how much it will stick out, but from the pic it doesn't look like much.
This is what I mean and you can put a line fuse in I used the ciggy lighter plug and socket so didnt need oneSwordfish said:The fuse tap is supposed to be better because they won't loosen your fuse connector in the long run. It allows you to "tap" power while keeping the original fuse intact, so you'll end up using two fuses -- the original one and another for the device you're installing, in your case the camera. The setup also looks cleaner. I'll try to take a photo of mine later. You can get a pair for only $3. You might as well buy a set of 2-amp fuses for the dashboard camera.
Ebay Fuse Tap
