Need help on how to download them from Google drive --- Please
lilac
1) Which following update is the most recent & reliable? how to download it from Google Drive & the upload to Dome G90 - 7S GS90C?
20150209 GS90C Ambarella A7LA70 with GPS
https://drive.google.com/open?id=0Bw8LfG-2RaLhRUFZUGVyX1prZWs&authuser=0
20150307 GS90C Ambarella A7LA70 with GPS
https://drive.google.com/open?id=0Bw8LfG-2RaLhQUlOQ3BOai00Ymc&authuser=0
2) How to download it from Google Drive? does it work better for this model, comparing with VLC player & "Registrator Viewer"? are anyone of them safe considering some from Russia or somewhere???
Blackview Player( play gps video )
https://drive.google.com/open?id=0Bw8LfG-2RaLhLVdVNTZFbURlTFU&authuser=0
From what I remember, 1110 has the speed in MPH and 1138 in KPH. For both, the GPS speed it's always displayed (when no GPS, 0 km/h).
How to download ?
- The download button is on the top-center of the page.
How to change the firmware ?
- Just place the "firmware.bin" on the root the SD card. Then when you remove the USB cable (if the camera is connected to PC) or when you start the dashcam you'll have the choice of updating the firmware (you can also choose X to avoid the update).
- It's important to connect the dashcam to some power source. (tip: the USB cable on the suction cup is only for power; it has two wires inside).
About video players
- Both VLC and Regitrator are fine. Don't worry if one is from Russia (it's not made by Putin :p). Blackview Player is way behind Registrator.
Software update done, thanks for help. But not really anywhere improving videos.
What needs improving? Firmware will rarely fix a blurry image (assuming) If the image is soft, it's possible your camera is suffering from heat related focus shift, or came short focused from the factory. I'm not familiar enough with the G90 to know if you can DIY adjust or if you'll need a RMA replacement.
I am not so sure if it is off focus, but day video is fine, night videos is ok as long as there have enough light. G1W allows us to adjust the exposure while GS90 - none, G1W has a better night exposure although both night/day not as sharp & detailed as GS90.
So, I would think it is more on the exposure or hardware issue.
