Hi all. I am new to this forum. Like many others I am sure, I became interested in dash cams and my research on the internet led me here. Also like many I am sure, I am completely overwhelmed with all of the alternatives that exist and cannot even narrow down the choices to a reasonable number.
In doing my research, I came to the conclusion that I want to deal with a company or seller/reseller that I can trust and that will provide support if needed. Seeing a lot of posts here from pier28 and recommendations for the products they sell.
That all said, I am looking for recommendations not only for the cams I need, but the accessories and add ons as well that will allow me to accomplish my objectives.
I am looking for two different set ups.
First:
I own the first car. So permanent installation is ok as long as its not too complicated. But at any rate the system will remain in the car.
This will be a front and rear cam system
Requirements front cam:
Clearest video possible during the day
Clear video at night within reason - less important than day
Must have a screen to be able to set options, either integrated or separate but not hard wired
GPS not necessary as I cannot see a need for this - unless I am missing some need
G Sensor required
Wi-fi not necessary
Somewhat discreet - dont want to smash and grab target or view obstruction
I am in Florida - so need something that works in extreme heat - capacitor verses a battery
Reliable with support, relatively easy and available firmware updates
Parking mode based on G sensor preferred, but will consider one that is on always but easy to turn on and off
Price range - up to $250 (or close)
Requirements rear cam:
Somewhat clear video within reason
Set and forget
stealth - dont want this to be overly obvious from behind
No screen or separate screen that does not need to be hard wired
Again - hot climate - must be ok in extreme heat
GPS and wifi not necessary
G Sensor required
Parking mode based on G sensor preferred, but will consider one that can be always on but easy to turn off/on
Price range - up to $150 (or close)
Also looking for whatever good or necessary accessories with this that will be useful - cost separate from that quoted above...such as mounts, wiring, power packs or options to power the cams in park mode and not kill my battery. If possible, tell me where to buy these too..
I will post second setup in reply below.
Thanks to all in advance...
First:
G Sensor required
Wi-fi not necessary
Set and forget
G Sensor required
