Edison (BlackVue)
Mar 28, 10:24 PDT
Dear Customer,
Good day from BlackVue.
I am very sorry to inform you that as of now we have no information about the compatibility of DR900S with rear truck version camera.
Because DR900S camera does not have a truck version.
And we can say that DR900S is not compatible for a rear truck version camera.
And we don't recommend using the rear truck version for the front dr900s as of now.
Hope you understand
Thank you
Best Regards
Me
Mar 28, 10:31 PDT
Can you please explain the notes in the firmware for this page then?
https://www.blackvue.com/downloads/#firmware-current
Specifically this part:
* Added compatibility with Interior IR and TRUCK IR cameras.
Also, this blog post:
https://www.blackvue.com/introducing-blackvue-dr900s-2ch-ir-the-new-taxi-dash-cam-standard/
Where it also mentions that the DR750S and DR900 share the same IR cameras via firmware update.
Edison (BlackVue)
Mar 28, 15:14 PDT
Dear Customer,
1. Turn off the proximity sensor:Firmware settings > System settings > Proximity sensor:
Voice (audio) recording On/Off
Manual recording
Off (NEW)
The new firmware version of the DR900S has a feature to turn off the proximity sensor.
The proximity sensor is used primarily for Audio Recording ON/OFF feature.
SD Card Failure Alert: your dashcam constantly monitors the microSD card to detect write protection errors. If the microSD becomes write protected, a “Check SD card” voice notification will play from the dashcam.
This SD Card Failure Alert will help the use to know if there is an issue on his / her SD Card on the dash cam.
The dash cam will have a voice notification that will say "Check SD Card".
Interior IR and
TRUCK IR cameras.
I am very sorry for the mixed up.
This firmware version will let your DR900S-2CH dash cam that will be compatible with Interior Camera and TRUCK IR Cameras.
This firmware version will help your dash cam to be compatible with IR camera like DR750S-2CH IR rear camera or DR750S-2CH TRUCK rear camera.
Hope you understand
Thank you
Best Regards
Me
Mar 28, 16:10 PDT
OK, so we’ve established that the new firmware will make the DR900S-2CH compatible with the TRUCK IR camera.
Back to my original problem … When connected to a TRUCK IR camera, the colors are washed out, and green looks purple, etc. Is this a known problem? Is there a setting or INI file change that can correct the color issues when connected to a truck camera?
Edison (BlackVue)
Mar 29, 09:05 PDT
Dear Customer,
Can you please provide us a sample video recordings?
So that we can help you for further assistance.
Thank you
Best Regards
Me
Mar 31, 17:03 PDT
The normal DR900S rear camera compared to a DR900S connected to a DR-750S TRUCK camera.
* Both cameras connected to the same DR900S
* Both cameras connected using the same cables
Edison (BlackVue)
Apr 1, 09:19 PDT
Dear Customer,
I am very sorry to inform you that as of now we have no firmware version for the compatibility of Truck version to our DR900S dash cam.
And as of now we just have the normal IR rear camera not the TRUCK version camera.
Hope you understand
Thank you
Best Regards
