Dee_82
- Sep 7, 2014
- United Kingdom
- Thinkware F750
Initial Thoughts
Bit of background, i am coming from a Thinkware F750, modified to a F770 and have loved it, its done its job since its initial release a decade or so ago, got me out of a couple of insurance jobs and more than paid for itsself after a year. But it decided its had enough and failed last week so did some research and and weighed up costs and thought, to hell with it. i spent £300 last time im sure i can do better this time.
A229 plus Rational
Choose this over the pro for two reasons, firstly, its quite a bit cheaper and secondly, 60fps in high lighting conditions should be more benificial then 30 which was the only real problem i had with the thinkware, its 30fps at 1080p was just not quite good enough, very close and mostly ok but not quite, so i figured if we can get get a good boost in resolution, bit rate and FPS, we should have more than enough detail to see whats going on. I figured that 4K is probably excessive and your paying a premium for something thats probably not really needed. 4k has its place, for example of a 65In TV its hands down better at a sensible distance over 1080p but on a 32in screen, at a sensible distance there is no benifit at all, i suspect the ability for the sensor to get that much data from a lens behind a dirty bit of glass thats at an angle to the Sun is going to cause far more issues during the day. But i conceed night time might be different story, thankfully thats not really a problem here.
Initial Conclusion
Really impressed with the quality of what arrived, box to accessories, was all very impressive for something that cost less than half what i paid for a F750, install was straight forward, bit disapointed to see aluminium wires but i get thats probably how its so cheap. Hardwire Kit went in without any bother, nice and simple. Setup of device seems to have an overwhelming level of settings which is good for me but i wonder if for less tech savy users much of this should be hidden behind a advanced menu setting or something.
In terms of quality im seriously impressed, i thought my F770 was good but this is almost as good as some of my Home CCTV. very clear, very smooth, MASSIVE file sizes but thats what you get with max bit rate, high FPS and higher resolution! Im sure teh 4K might well have been evern better but the question is really, does it need to be, the higher you push that bar the more extreme the edge case is for its requirement, i guess there is an argument to be said for having it and not needing it rather then needing it and not having it but we did just fine 10 years ago the police etc had no better then what we have now so im pretty comfortable that there is unlikely to be a situation we would need it and at well over £200, im just not feeling it for the pro. Maybe i will regret that, maybe not, time will tell.
I have a couple of questions that i want to answer and will do eventually but would welcome thoughts.
Does Auto HDR mode switch from 60FPS to HDR during the time specified or is it completely disabled if 60FPS is choosen.
Dashcam Viewer doesnt seem to recognise the embedded GPS and meta data, need to figure that out.
Theres a another wifi setting on the device that doesnt appear to do anything, cant think of the name off my head but you can specify and SSID and password but its NOT the hotspot you connect to. need to figure that out, would like to be able to link it to my IOT network in the home but i suspect thats not possible.
Rear camera is a bit iffy with reflection, will purchase the filter and see if that helps.
All in all, really happy with it
A229 plus Rational
Initial Conclusion
