Next base 422GW freezes when rear cam connected
Dazzling_Brain_
bristol
Hi all
I'm currently experiencing problem where my rear camera isn't working when connected to the man 422GW – on the main camera screen I only get a transparent frame where the rear camera feed should be, and recordings stop after around 9 seconds. However, if I disconnect the rear camera from the main unit, the front camera works normally.
As the rear camera cable is hidden behind the trim in my vehicle, I'm keen to avoid replacing it unless necessary. Has anyone had this issue and replaced the rear cam cable or rear cam or both? i dont think the from cam is faulty as i tested on 422gw and 522- i have the same issue.
Any information would be greatly appreciated. My rear camera is around 7 years old, so it's unfortunately out of warranty.
Thanks in advance for your help.
