HI, I bought a 112 as a Christmas present for my son. I have tried several different SD cards ( I have tested a SanDisk 32Gb class 10 for corruption and fakeness) but it doesn't seem to format or record to any of them.
The SD card is recognised as being inserted (icon in the bottom left hand corner), but it comes up with error when you try to record. When you go to Format it does the process in about a 1 second, not sure if that is too quick for a 32Gb card)? But still errors.
I have tried to update the firmware, but it doesn't flash as suggested and when you go to Information it still shows the old version number. If I then format the card in the 112 and then look at it on the PC, the firmware file is still on the card.
Can anyone tell me if these dash cams have this sort of problem?
